Got a customer with a 61 389 car. Will the Long branch manifolds fit ok? Will he need any other special adapters?
--------------------------- Fool Around, Get Hurt, Don't come Crying to me. |
I have a set of long branch on my 63 wagon.
You must have the oil filter adapter for them to work. Use the adapter for the firebird. I also recomend using the Firebird longbranch because they are narrower than the big car. 2 1/4 vs 2 1/2. You might have a slight problem with the drivers side touching the starter. Use a short solonoid. Contact Me for more details. ------------------ Mr. Z
Try calling CRUSHPROOF! 512-386-9889 |
My experience has been that the big car has a 2.5" outlet, while the Bird only has a 2 1/4".
Check that adapter carefully for oil flow. They ALL have to be modified for proper oil travel. |
Case in point:
I had to epoxy [JB-Weld] an internal cavity in the oil adapter so that it would actually send oil to the filter, without making a U-turn back into the motor. Even had the proper gaskets. "his peg-leg got woodworm, and broke into three" --G. Baker
12.24/111.6MPH/1.76 60'/28"/3.54:1/SP-TH400/469 R96A/236-244-112LC/1050&TorkerI//3850Lbs//15MPG/89oct Sold 2003: 12.00/112MPH/1.61 60'/26"x3.31:1/10"/469 #48/245-255-110LSA/Q-Jet-Torker/3650Lbs//18MPG 94oct Sold 1994: 11.00/123MPH/1.50 60'/29.5"x4.10:1/10"/469 #48/245-255-110LSA/Dual600s-Wenzler/3250Lbs//94oct |
Ccass,
Is this car stock? Is the drivetrain modified (later engine/trans) I have encountered some minor problems.
Car is a stock 389. We're looking for both frame clearance and oil filter clearance.
Ccass,
Go with the firebird Ho longbranch. Use the firebird adapter. You might have some starter clearence problems. A slight grinding or shorter starter solnoid will be required. Contact me for more details. ------------------ Mr. Z
