Old 07-01-2021, 11:28 AM
Gary H's Avatar
Gary H Gary H is offline
Default Clevite MS667HX main bearings
I'm rebuilding a 455 SD for a customer and the new Ohio crank I bought for it is fat, and on the high side spec wise I'm looking for an extra clearance bearing for the 3.25 mains and the only one I see are the Clevite MS667HX. As with everything else these days no one has any. Do any of you have a set, or know off a place that has some in stock? I checked with Butler, KRE, Summit, and Clevite. All out
Old 07-01-2021, 01:17 PM
DOC DOC is offline
Can you polish the crank down some to spec?
Old 07-01-2021, 02:41 PM
steve25 steve25 is offline
Jeg’s is showing a set.
Old 07-01-2021, 04:25 PM
Gary H's Avatar
Weird, I looked earlier today and they didn't show any. Had to be ordered. I'll check again
Old 07-01-2021, 04:26 PM
Gary H's Avatar
No, it won't take material off consistently across the journal.
Old 07-02-2021, 10:46 AM
Gary H's Avatar
No businesses have them.
Does anybody have any in their collection of parts they would be willing to turn loose of? MS667HX Clevite
Old 07-02-2021, 08:37 PM
Richie Hoffman's Avatar
Richie Hoffman Richie Hoffman is offline
good crank shop can cut .001 off a crank
2008KRE Q16 Winner
2014 atco raceway doorslammer winner 86 grand am tube car 8.95 @152 455 eheads solid flat tappet cam
Hoffman Racing building and racing Pontiacs for 35 years
Old 07-02-2021, 09:05 PM
PAUL K's Avatar
PAUL K PAUL K is online now
X 2
Go fast, see Elvis!
Old 07-03-2021, 06:09 AM
Do you have any Bearings with a gray brake in coating that?
If you fine scotch brite that off with the aid of a very light oil that could give you a added .0015”.
Many builders do this .
Old 07-03-2021, 02:26 PM
Gary H's Avatar
I may go that route if I have to. Problem is we don't have any great crank grinders in the area
Old 07-03-2021, 04:35 PM
PAUL K's Avatar
That would make it difficult..... Is the housing bore to the max?
Go fast, see Elvis!
Old 07-03-2021, 05:00 PM
Gary H's Avatar
The crank is .0002 under the max. I calculated if we align hone the block, and put it on the max, I will have .0018 clearance. That's using the Sealed Power bearings which I actually measured. In my experience Sealed Power bearings measure thinner than Clevites. I don't feel comfortable with .0018 on an original 455 SD engine/car I'm shooting for .0023 -.0028. The pistons for it are going to take 10 weeks so I guess I'll see if Clevite gets the extra clearance bearings in stock between now and then. If not, I may take it to a crank grinder in town and see what he can do. Scary!
