Old 01-15-2025, 12:11 PM
C-Rad C-Rad is offline
Default Should I replace #94 heads with #13 heads on a 400?
I bought a 1968 Tempest convertible that has a late 1976 Pontiac 400 block (casting number 500557)
It has heads (casting number 94 (1971?)). The power feels a lot like my ‘66 Tempest with an stock 326 w/ 2-barrel, so sufficient but not impressive power (250HP??). I would like to increase the HP on the 400 up to 350-375Hp (I know the 500557 blocks don’t like more than that). I just want a fun street cruiser/daily driver.. It already has an Edelbrock performer aluminum intake and 4bbl carb. I don’t know anything about the cam, or if the cylinders have been bored.
I have an opportunity to buy a set of set of rebuilt heads (casting number 13) for $550, which have the big valves and smaller volume.
What kind of power increase can I expect if I swap out the #94 heads for the #13?
1966 Tempest convertible - 326
1968 Tempest convertible - 400
Old 01-15-2025, 03:14 PM
J.C.you's Avatar
J.C.you J.C.you is offline
I just did same thing with 13s and the later beveled lower compression factory pistons, good runner. I softened the eyebrows in the chambers a little to avoid a hot spot detonation area
1966 GTO dragcar
1966 GTO Ragtop
1969 Tempest ET clone street/strip
1969 GTO Judge RA lll, auto
1969 GTO limelight Conv. 4speed go and show (sold)
1970 GP SSJ
1972 GTO 455 HO, 4 speed, (build)
Old 01-15-2025, 03:41 PM
Formulas Formulas is offline
Buy the heads even if you dont need them, great price for cores let alone rebuilt
They will work fine on your engine as well
.................................................. .No One Ever Escaped Tyranny By Compliance..............................
Old 01-15-2025, 03:49 PM
steve25 steve25 is online now
It’s difficult to nail down a answer without known what cam is in the motor now..
Essentially you would be going from a 8 to 1 compression to about 9.4 to 1, that would gain you around 3.4 % more HP.
Figurine that at best now your making 240 hp so the gain in compression buys you about 10 more hp.
The Following 2 Users Say Thank You to steve25 For This Useful Post:
Old 01-15-2025, 11:19 PM
Joe's Garage Joe's Garage is offline
Default I think you'll see more of an increase than 10HP.
We did this several times on 1977/78 Trans Ams back in the 1990s and it REALLY woke up the engine.
With stock camshafts, we'd switch out to 1.65 rockers are the same time.
Then they felt a LOT like the 1969 and 1970 GTOs we owned at the time.
You not only pick up compression, you also pick up the increased flow from the larger valves.
Plus the increase in power having a fresh valve job and new springs, etc.
Go for it!
The Following User Says Thank You to Joe's Garage For This Useful Post:
Old 01-16-2025, 05:39 AM
While the HP gain might not sound like much the difference in throttle responce is and the increase in fuel mileage is nothing to sneeze at either these days.
Old 01-17-2025, 11:36 AM
J.C.you's Avatar
Just saying only 10 hp is deceiving to someone that may think, why bother? I hear this frequently on the boards by keyboard warriors armed with simulation hardware.
That’s across the entire useable rpm range of the engine. Carry on
1966 GTO dragcar
1966 GTO Ragtop
1970 GP SSJ
The Following User Says Thank You to J.C.you For This Useful Post:
Old 01-17-2025, 12:48 PM
Kenth's Avatar
Kenth Kenth is offline
Fresh #13 heads + 068 cam equals fun 400 engine, even with the beveled pistons.
JMHO
1966 GTO Tri-Power
1970 GTO TheJudge
http://www.poci.org/
http://gtoaa.org/
Old 01-17-2025, 08:11 PM
Great point!
I forgot that motor has the chamfered pistons .
Go right ahead and bolt the 13s on!
Old 01-18-2025, 06:07 AM
Info.
Change in Hp.
Thread Tools
Display Modes
