WHERE AND HOW TO GET Norwalk info sent??
Is it to early to ask, would like to get some info sent to the house, where can i find it or who do i call??
Should be all you need.
1964 GTO 501, Edelbrock Heads NA, 3460 lbs. 9.76 @ 137mph 1971 Trans Am Lucy Blue, 11.56 @ 115 1966 LeMans. 462, SD prepped Kaufman D ports. 11.90 @ 112 1976 Trans Am twin turbo 462, SD Edelbrock heads 8.50@159 2009 G8 GT |
You can call Super Duty Promotions at 419-663-7383. You can also try Pontiac Nationals.com They have quite a bit of info on the website.
As far as getting there my Gps unit does not find it. Anyone else have this problem?
If you go you will not be dissapointed, there is about 900 cars there equally split between racers and show cars. Its 375 miles for me 1 way and its worth it just wish I could spend more time there. |
Been there last 4 yrs., i just did not see anything posted yet, getting worried, thanks for the info. gang!!
Just show up at linders lot, no need to pre-register, you can regiester and pay right their, the earlier you get their the better pit spot you will have.
74 Formula 469, 6X-4's, 72 Intake, Ramair Manifolds. 3 inch exhaust with x-pipe Custom Roller Cam, 1.52 Roller Rockers Quadrajet done by Cliff 3:42 gears 12.075 @ 112.70 12.092 @ 112.43 12.128 @ 111.71 |
About the GPS - try 1300 Akron Rd, Norwalk, OH For some reason the GPS doesn't like State Route 18 - I work at the track sometimes and that seems to work for the guys I've talked to on the phone. Andi Woodruff andi@pontiacnationals.com |
