Old 05-09-2021, 09:32 AM
78w72 78w72 is offline
I'm running the MT Sportsman S/T's...so far I like them better than the BFG TA's, and they were cheaper and have nice smaller solid white letters that have stayed white over the past 2 years since I bought them.
My only complaint is the perimeter sidewall scallops/ribbing (for lack of a better term) looks too heavily textured to me. I prefer the total smooth sidewall look like on the original Wide Ovals and Polyglas tires, even the original Goodyear Eagle ST's...but, still they are very good tires.
Dennis
Dennis
yeah they do have more tread ribbing on the sidewall than a BFG or other period correct repro tires, ive seen a few "modern" radials look like that, cooper cobras have the same look & even have an added band under the sidewall tread, this pic shows it somewhat but its even more pronounced in other pics online.
Old 05-09-2021, 10:23 AM
SD455DJ SD455DJ is offline
Maybe they are there for improved water rejection(?)...sounds good to me!
Dennis
Old 05-09-2021, 10:27 AM
hard to say why, but many of the modern higher speed rating 15" tires have that look, cooper & the M/T have the same speed rating & a similar tread pattern.
Old 05-09-2021, 04:23 PM
Formulabruce's Avatar
I think they call them all season. That could be why
Old 05-09-2021, 09:02 PM
racerboy's Avatar
racerboy racerboy is offline
That would be interesting , considering that I’m guessing that less that 10% of these cars are used ‘all season’.
Three times the sound peaks, falls back, peaks again. A throttling back to cruising speed, a dwindling grumble of thunder and...gone.
The frogs take up where they left off.
Old 05-09-2021, 09:20 PM
racerboy's Avatar
I’m still torn between the less expensive BFGs (or M/Ts) or just springing for a set of Firestone Wide Oval radials. Of course, if I went the Firestone route, wouldn’t it make sense to just swap out the GY PolyGlas tires and keep the car riding in the JW wheels, whine I think look much better than the later 15x7 wheels.
By the way, the previous owner (Gary in CA) told me he bought those PolyGlas tires in 2009. They have less than 5K miles on them, but is it a good idea to run around on 12+ year old tires, regardless of the miles?
Old 05-09-2021, 10:28 PM
weranc55's Avatar
weranc55 weranc55 is offline
As long as there is no cracking I wouldn’t worry about it. I would go the bfg route if you want to drive it. No disrespect but those m/t’s with the thread on the sidewall look like a mud tire.
Old 05-10-2021, 12:50 PM
Chuck, They really do help when I'm boondocking in the Formula (hehe!)...
Dennis
Old 05-10-2021, 07:52 PM
If you do not think a 60 series Radial on a 7 inch tim will "roll" an Inch or more, look it up. Plenty of video proof.
Old 05-12-2021, 09:00 PM
Ponchy's Avatar
Ponchy Ponchy is offline
Send a message via Yahoo to Ponchy
I picked up a set a clean set of 15x7 Rally II wheels for my '70 TA.....What's the widest I could run (on a 15x7 wheel) and would you recommend staggered widths (a bit narrower up front)?
According to Google, it appears to be P255/60R15.
This will work with stock suspension.
