Right Stuff Detailing front discs and SPC control arms?
Any of you guys using this combo and did you have any fitment issues?
I used this disc brake kit http://mbmbrakes.com/1964-1972-gm-a-...c-booster-kit/ and I'd be willing to bet this is the same kit or very similiar to what right stuff sells, I have both the SPC uppers and lowers and have zero fitment issues on my 65 LeMans not sure if a drop spindle would throw a wrench into anything? Only issue so far is that I used the longer link on the front side of the upper and have over 7° of caster and they couldn't get the -.5 of camber set, going to swap the links and get it aligned again.
65 LeMANS , SD performance 462ci Engine, Tremec TKX 5 speed with a 3.73 geared 8.5" 10 bolt |
I have an mpbrakes classic kit (before it was called a classic kit), with SPC uppers and lowers.
The brake kit is a standard 11” disc with d52 calipers deal that would be found in the right stuff kit.
