Since the same problem happened on two starters and brands could there be something else going on? |
This has happened over the course of many years, 2 different 455's and now twice on his 571. So different blocks, different flexplates. I'd have to guess he's had 3 or 4 different types of mini starters on it before settling on the RobbMC. Learned rather quickly that the other style like the powermaster with the gear hanging in the breeze, when that falls off it's a 50/50 chance it'll be found. He was lucky once and found it, slid it on, started the car and drove it home. I guess the good news is that when the C-clip fails it's pretty easy to replace the C-clip and keep on going as long as you still have the gear. That's what dad did after he got the car home. Snapped another clip in and continued to use the starter for a while. RobbMC uses a different retention method as mentioned, and have had that fail twice over maybe a 5-6 year period? So it's not a frequent thing, but when it does happen, at least it has a pinion support so the gear doesn't go anywhere. Worse case it stays engaged in the flexplate and loosely rattles around. So just shut it off and start again. If it freewheels I have to reach under and push the gear back. But at least I know when it does that, it's not the end of the world, I can still get the car started and drive it home. In fact the last time dad drove the car for a while like that before bothering to fix it. That's one benefit I really didn't think about with the pinion support. Funny part, he took the car to the Pontiac races like that a couple months ago, and once started in the pits he just let the car sit and idle in the staging lanes rather than starting and shutting the car off constantly moving up the line and risking a chance he might have to crawl under the car and push the gear back., made his run and came back to the pits. Sent it back to Robb that Monday and he had it back Friday fixed for free. Can't complain. It'll probably last another few years I suspect. To keep from having down time the next time it happens, he bought a spare RobbMC starter. |
The Following User Says Thank You to Formulajones For This Useful Post: | ||
https://www.summitracing.com/parts/pwm-9410
James 1970 Trans Am Spotts Built 484" IA2, Highports, EFI Northwind Terminator X sequential EFI fabrication and suspension by https://www.funkhouserracecars.com/ Last edited by R 70 Judge; 09-22-2022 at 04:15 PM. |
Summit sells them for $196 and free shipping
Tim Corcoran |
I went with the 9510 and it was right at 200 shipped.
79 Firebird/`70 400 with `77 6x-4s shaved .065"/4 speed BW ST-10/Cliff Q-Jet/XE268/3.08 99 Trans Am/383 LS1/TSP headers and catback/custom grind cam/Vigilante 2500/Strano springs and Konis 08 Corvette - Base (SOLD) 75 Corvette/L48 350 (LSx -4L60E one day) -------------------------------------------------------------- |
Question for you. Hopefully this doesn't sound dumb. First time seeing the Mezeire billet flywheel and was wondering if, because it's billet being to stiff? As the Flexplate has to flex. Just a thought. Looks like a very nice part. Thinking of getting one. Thanks
How's the clearance on these things with Ram Air manifolds? Can't be any worse than the factory solenoid I suppose. Just trying to eliminate the chances of an electrical meltdown. Came close to one a few years ago with the stock setup.
Ken '68 GTO - Ram Air II 464 - 236/242 roller - 9.5” TSP converter - 3.55 posi (build thread | walk around) '95 Comp T/A #6 M6 - bone stock (pics) |
It made no difference either way however. Worked and started the same. Only thing I noticed is it makes it easier to install/remove the solenoid wires, lol. Last edited by Formulajones; 09-26-2022 at 04:13 PM. |
Grab the jegs branded one, cheaper and power master makes them for em if I remember right. Works with the tri y’s.
77 T/A- poncho 400| T-10|3.23| I beams|Hyper flat top pistons|Kre heads|Scorpion rockers|Xr276 hydro roller|Rpm intake|Smi qjet|Subframe connectors|Rancho sways|Mcleod super street|hydro clutch|More i cant remember |
The main reason I went with a nippodenso starter was for the hotstart issue and have luckily been trouble free for me so far. |
I ran one of the powermasters on a 400SBC about 25 years ago. It was my daily driver and after about 2 years of daily use that starter started making a little noise. Nothing horrible but I noticed it started getting louder on the flexplate. Never left me stuck. So I pulled that starter and the snap ring was still intact but I noticed when I grabbed the gear it would wobble just a bit. I suspect the bushing support was starting to wear which was always one of my concerns since that gear just sticks out with no support on the end. When that thing jumps out and engages trying to spin the engine over, that's a tremendous amount of force on the gear and shaft. I still have that starter up on the shelf. Most guys here don't daily drive these cars though, so it's probably not something most would worry about. With the little driving that most do with their classic cars, one of these starters might go 5 years or 10 years without a problem. |
Another little tidbit of info some may or may not know.
Every since that minor incident with the 400sbc I mentioned above I've been a big fan of the nose cone support or pinion support, what ever you want to call it. With Pontiacs unfortunately you don't get a lot of choice. I think RobbMC is the only offering. But some of you guys also have Chevrolets and on those what I did starting back in the 90's is running GM's mini starter. All GM starters have nose support. GM started with mini starters on the V8 LT1 in 92 and LS engines in 96. So on all my BBC engines I started installing GM LS mini starters. They bolt right on for 168 tooth flexplates, all you need are slightly shorter starter bolts because the bodies are so small. But they spin over my BBC's no problem. In fact my Chevelle has had the same one on it since about 1998 and it gets driven regularly. Not daily but several thousand miles a year. That thing still spins over tight. Excellent little mini starters. Back then those LS mini starters weren't that expensive either. Today I'm not sure, but I went that route decades ago on the Chevrolets and never an issue with those. |
I bought one of these for my firebird its worked well
So far.
Happiness is just a turbocharger away! 960 HP @ 11 psi, 9.70 at 146. Iron heads, iron stock 2 bolt block , stock crank, 9 years haven't even changed a spark plug! selling turbos and turbo related parts since 2005! |
James 1970 Trans Am Spotts Built 484" IA2, Highports, EFI Northwind Terminator X sequential EFI fabrication and suspension by https://www.funkhouserracecars.com/ |
The Following User Says Thank You to R 70 Judge For This Useful Post: | ||
I'll jump in here with some more comments. I'm building a road race engine and am using the Canton "T" pan with Hedman headers.
The engine that came in the car had a CVR starter; which is the Nippon Denso type like the Powermaster. With the starter rotated inboard, it interfered with the pan. With it rotated out one hole, the wires would be dangerously close to the headers. I'll be running hot for 20 minutes at a time. The RobbMC website shows dimensions on their starter compared to the Denso and Hitachi styles. Based on it being smaller than the other styles, I ordered one and got it with the pinion support for extra ruggedness. Here's the first bit of happy news. Ordered on Tuesday, shipped on Wednesday, just got notification that it's on my doorstep today (Friday). Eric
"Everybody has a plan until they get punched in the mouth" noted philosopher Mike Tyson Life begins at the end of your comfort zone. “The mind, once stretched by a new idea, never returns to its original dimensions.” |
That's the great service with RobbMC.
You can flip that starter 180 and have the solenoid on the bottom, as long as your kick out pan allows it. Sure makes accessing the wires a breeze. Actually the starter is infinitely adjustable so you should be able to find a position that suites you. You'll see what I mean when you have it in your hands. |
I had a RobbMc on my shopping list for a while, but the Powermaster 9510 praise combined with a discount from Jegs which put it a little under $200 made it hard to pass up. I guess I never paid much attention to these starters before, because the size and weight difference is huge! I hear the concern about the pinion sticking out in the wind we'll see how it goes with this one.
The Following User Says Thank You to Verdoro 68 For This Useful Post: | ||
Thread Tools | |
Display Modes | |
