Finishing some upgrades for my 80 TA
Been working on this during my spare time for a while. Kind of excited about some of the upgrades. The old combo ran 10.6 @ 127 weighing close to 3900 lbs. with driver and a full tank of fuel.
464 was replaced by a AP 496 pump gas short block. 318 87 cc E-heads were replaced with 330 cfm 87 cc. Ported T2 was replaced with a more ported T2 175 HP integrated nitrous lines were replaced with a Big Shot NOS spray bar Custom 3/8 in carb spacer was added to increase plenum volume and raise the hood scoop a bit. Same carb but different boosters. Flows around 1000 cfm. TSI tight ten inch converter was replaced with a tight ATI 8". GM 3:42 10 bolt was replaced with Mosier 9" housing and axles with a 3.50 gear, Strange center section and Detroit locker. Factory drive shaft with original style Lakewood u-joints replaced with Strange driveshaft and big u-joints. Modified factory fuel tank (stock in appearance) used with two Holley blue pumps replaced with sumped fuel tank and Magnaflow fuel pump. Last edited by PAUL K; 10-02-2022 at 01:40 PM. |
The Following User Says Thank You to PAUL K For This Useful Post: | ||
Now for the cool stuff!
Found a Hooker Show Bar from a local member here and he was nice enough to include free installation with the purchase price. Had a factory 8k tach upgraded with modern electronics. Came up with a sticker for my fake battery. |
Looks AWESOME Paul. Your going to give those Texas tracks a proper introduction.
The Following User Says Thank You to Jay S For This Useful Post: | ||
What mufflers you running ?
The Following User Says Thank You to slowbird For This Useful Post: | ||
They are Walker mufflers I believe they are called their "welded" series. They are a straight through design and pretty quiet. Here's what they sound like with the old combo https://youtu.be/PhDicneJIXs |
ULTRA FLO WELDED
https://www.dynomax.com/mufflers/ult...elded-mufflers Great muffler. I use the same one.... https://www.youtube.com/watch?v=sY76buhCPWg Sounds like it will be a great combo Paul. See you at Ennis .
The Following User Says Thank You to Steve C. For This Useful Post: | ||
That's a badass setup! I'm sure it'll fly
Love the show bar!
"Those poor souls have made the fatal mistake of surrounding us. Now we can fire in any direction" 1970 Trans Am RAIII 4 speed 1971 Trans Am 5.3 LM7 1977 Trans Am W72 Y82 1987 Grand National |
Gorgeous Firebird thanks and thank you Steve c Beautiful bird also.
The Following User Says Thank You to Gach For This Useful Post: | ||
Great ride . I really like the sleeper look with that car. You have certainly changed a ton in the car, excellent upgrades. I’m very eager for a report on how it works on the street and at the track .
I have a fake battery also contains my fuel pressure reg. Where did u get the tac upgraded? |
Maybe a 9?
72 lemans,455 e-head, UD 255/263 solid flat,3.73 gears,,,10" 4400 converter,, 6.68 at 101.8 mph,,1.44 60 ft.2007 (cam 271/278 roller)9"CC.4.11gear 6.41 at 106.32 mph 1.42 60 ft.(2009) SOLD,SOLD 1970 GTO 455 4 speed #matching,, 3.31 posi.Stock manifolds. # 64 heads.A factory mint tuquoise ,69' judge stripe car. 8.64 @ 87.3 mph on slippery street tires.Bad 2.25 60ft.Owned since 86' |
Also interested in the tach..my stock one doesn't cut it but I have a spare 8000 rpm tach.
I had a guy that redid the tach in the 81 I got from nastyZ28.com forums. Also added the higher mph speedo I had picked up years ago and matched font on the face. Nice job
Thanks... I was stoked when I found it. I initially picked it up for a friend's 70 Z/28. After I got it to the shop and started thinking about it .... I was fortunate enough to talk him out of it.
Hi Scott, the engine probably makes enough power to run nines, but I'm thinking I'll end up around 10.20. The car twists up pretty good leaving the line. I'll soften the launch to smooth things out. I also want to install bars from the firewall to the front of the subframe. I'm hoping that will help.
Your engine sounds sweet. Have fun dialing in the new engine. Looks like you have a LS killer. |
The Following User Says Thank You to Dragncar For This Useful Post: | ||
Have you made any passes at the Motorplex yet? I used to make the trek there at least once a year. I don't have the desire to go to all the races I used to attend. The Pontiac Southern Nats, sometimes raced at the Motorplex. I wish those days would return!! I like your thinking on holding e.t.'s to a desired time. Tom and Sharon Wilhites Pontiacs both run 10's easily (the red 58 and white 59, I'm sure you know of tem). Tom's white 59 has a 540 with 2 of those large single throttle bodies on a tunnel ram, Sharon's is a 505, similar combo. Tom likes the idea of being a little easy on his engines and chassis. It also saves a lot on safety equipment and extra mods if he ran quicker. I like that blue color, what a sleeper!!! Jeff
Wow, nicely done!
If you cant drive from gas pump to gas pump across the map, its not a street car. http://s207.photobucket.com/albums/b...hop/?start=100 |
The Following User Says Thank You to Region Warrior For This Useful Post: | ||
Thread Tools | |
Display Modes | |
