70 firebird non tilt steering column housing
looking for the upper steering column housing for a 70 firebird. the part that the keyhole is on and houses the turn signal switch. non tilt dont care about the color.... shipping would be to palm coast florida thanks
1970 firebird, 468, e heads, |
I have a column
I have a couple of these loose if no one else does (because shipping from Cabada can be a little steep).
I am not an expert, but believe this part is 1969-1978 or so. hopefully someone more knowledgable on the minute difference can chime in.
i dont need the whole column . just the upper housing that the ignition key and the turn signal is in. thanks
like this..but not the actual style
This is what I have;
I pulled it ages ago; If I recall correctly, I grabbed this because my column seemed to be boogered with the lock retainer, or ignition buzzer... Either way, this was one of a couple I grabbed, in part because disassembling this at a scrapyard was a great way of learning what I need to do. The fourth picture is fuzzy, but it made it that way so the the original colour is more realisitc (the other images seemed to be quite dark); The lock mechanism is (I believe) all still there, as are both seals. This collar absolutely needs to be sanded down, preped and painted.
thanks guys i found one locally.
