Old 04-22-2024, 08:34 PM
grd777 grd777 is offline
Default 1970 firebird seat belts
stripping a 70 parts car ,got some seat belt .they will have to be refurbished
listing here before i try ebay
$125 plus shipping
ID:	632491   Click image for larger version
Old 04-23-2024, 03:27 PM
Mr. G Mr. G is offline
Would you happen to have the shoulder harness belts for the '70 Firebird? Still need a set for my T/A.
Old 04-23-2024, 03:43 PM
sorry no ,that all i got
Old 04-23-2024, 06:07 PM
Thanks.
Old 04-24-2024, 03:24 PM
unruhjonny's Avatar
the first two small buckles are 1972.5-1974;
I don't know if they will even work with the single rear belt in the middle of the two buckle types.
The middle belt, and far right buckles pictured look to be correct for 1970-1972-1/2.
Here is a general description which might help for 1970 through 1972-1/2;
  • Front lap belts: 1970 recoiling / 1971 through to 1972-1/2 fixed length with vinyl sleeve
  • Front shoulder belts: fixed length with elastics to hang from roof (roof hangers were translucent plastic, and are often broken).
  • Front lap buckles: adjustable length (same ones for lap and shoulder)
  • Rear lap belts: short; fixed length
  • Rear lap buckles: adjustable length (shorter than the front buckles)
Mid way through 1972 seat belt laws changed, and this required a seat belt warning to be incorporated - the speedometer and gauge clusters changed at the same time to incorporate a "BELT" warning light.
These belts had a smaller buckle than earlier units, and of late they have been coined as the "exploding belts" because of the tendency for the front plastic faces of the buckles to pop apart rendering hte buckle almost useless.
These belts had smaller male ends;
The front lap belts for 1972.5 & 1973 used a shoulder belt much like earlier ones, except they interlocked with the lap female belt end - the end was unique;
Because of the shoulder belt interlock, these belts only had a single buckle for the front seats.
For 1974 I believe that the separate shoulder belt was eliminated - and this replaced the two piece belts with a (first year) one piece shoulder belts which had a recoiling base mounted on the ceiling.
I hope this helps
1970 Formula 400
Old 04-24-2024, 05:54 PM
Lightbulb George, am sorry to interrupt your ad.
To respond to Jon, the "exploding buckle" Irvin seatbelt buckles/matching male ends were not used in the short season, late '72 model, F-body seatbelt sets. The small textured plastic buckles made their first F-body appearance in '73 model F-body's (first production models mfg very early Oct '72).
Of note, the first GM use of "exploding buckle" standard seat belts were in late '72 model Pontiac A-bodies. Have a complete set I removed from an extremely low mile '72 Lux LeMans built 01C Pontiac. Need to ck the vendor, they were not mfg by Irvin.
Old 04-24-2024, 06:09 PM
unruhjonny's Avatar
thanks for the correction;
That sounds correct - and has jogged some of the webs out... The belts DID change though.
Sorry for my bad information
1970 Formula 400
Old 04-24-2024, 11:31 PM
I hope this helps
thast what i pulled out of the 70 parts car
