Lincoln Mark VIII Fan Testing
This was posted on my FE Facebook group. Its been discussed on here though so I thought I would cross post the info. Not my test, Im sure some of you can dispute the method. But its better than nothing.
Basically this dude tested a factory Mark VIII fan against two Rock Auto type re-pops. I know I have wondered how the re-pops actually perform. Pleasantly surprised if these numbers are to be trusted. Writeup below is copy/pasted with some bolding to make it easier to read. ------------------------------------------------------------------------------------------------ Did some simple flow testing on the 2 speed Lincoln Mark VIII style fan I run on the Dart to see which is the best. Never had heating issues with these 2 speed fans but with new brushless technology out I'm sure there's a ton better out there now. I used the old radiator from the Dart in front of them to get true flow numbers with the pressure drop of a core in front. Made sure the testing voltages were the same, and needed a battery to calm the inrush current and maintain current. These pull huge (50+ amps) on high speed when starting. The stock Ford OEM fan flowed the most, followed very closely with the Dorman 620-118 then the TYC-620950. Between the Dorman and TYC, the Dorman is made in Thailand and the TYC in China. Thailand seems superior as they revamped the fan blade design and flowed closest to the stock design. With a higher voltage on high speed I can see these fans getting close to 3800-4000CFM at 14.4V. Without a radiator in front the low speed amperage dropped 3-5 amps and the full speed only about an amp or so. Results were as follows Stock Ford fan : High speed 3415 CFM 22 amps @ 12.7 Volts Low speed 2800 CFM 18 amps @ 13.7 Volts Dorman : High speed 3355 CFM 22 amps @ 12.7 volts Low speed 2578 CFM 16 amps @ 13.7 volts TYC : High speed 3116 CFM 22 amps @ 12.7 volts Low speed 2578 CFM 17 amps @ 13.7 Volts
I used the M8 fan too. I have 2nd for a spare. I ran it with DCControl controller.
I know they have been used by lots of people with great fanfare. (Ha!) The interesting part for me in this was that the available new units are at least reasonably close in performance to the venerable original. No matter how good the reviews I’m loathe to trust a nearly 30 year old electric fan.
This is really good info. Would you mind providing fan shroud dimensions?
Sean 1967 GTO Koerner built 468 with Edelbrock RP’s 315cfm by Butler, Luanti Voodoo HR 20510713, 4l80e, Holley Terminator EFI |
That said, tons of people use these. Google Im sure would turn up the answer. I know they are pretty deep for an electric. I think you need like 6" of clearance to use one.
The Following User Says Thank You to dragracerx2813 For This Useful Post: | ||
Or even buying the Dorman and then purchasing a VDO motor so you get a new shroud and blade. At this point I think I have my clutch fan sorted, but I still like the idea of maybe going electric so you can switch the fan on with the car off.
We have both the single speed Mark VIII fan and the 2-speed fan that came in the T-Bird during the same time period. Lincoln used the computer to control the speed of the single speed fan so it was basically a variable speed fan. My observations are that the single speed fan pulls more amps and definitely pulls more air at full voltage than the 2-speed. Maybe a moot point because the two-speed was in our Firebird and wired where the thermostat controlled low speed and a dash override switch would activate the high speed. In six years there was never a time even on the hottest days that the high speed was needed. The single speed fan in my drag car is controlled by a Flaming River variable speed controller and it has never had to go full tilt to keep temps cool.
Still prefer the total reliability of a manual fan setup on the street. Have friends with a wide variety of electric fans and controllers, and have kept several of them company alongside the road while they waited for the tow truck. Always a fuse or controller issue and never a fan motor failure.
Mick Batson 1967 original owner Tyro Blue/black top 4-speed HO GTO with all the original parts stored safely away -- 1965 2+2 survivor AC auto -- 1965 Catalina Safari Wagon in progress. |
The shroud is 22x19
Got 2 UpullIT Elec fans: 1 in GTO, 1 spare. Low setting doesn't help the Summer heat load. So wired for High Speed only.
Manual Turn-on thru Relay. Someday i will automate Turn on with the $11 Head Thermoswitch. Only needed at Stoplights on hot days and Summer highway. No mech fan. High Setting helps completely; Been a Dozen years, Spare fan on Garage wall for when I turn 65 or so. |
I dont want to start another, flex fan vs clutch fan vs Mark 8 battle, but I am curous how well a Flex-A-Lite 7-Blade Fan 116441 flows, if anyone has any idea?
Of course the flow would depend on engine speed, and at some point with blades bending over it would be maxed out. Seems an electric fan wuld be nice when stuck in traffic. |
Also, it seems like only a 6 blade 19" flex fan is now offered which would reduce air flow with the smaller diameter and one less blade.
1967 Firechicken, 499", Edl heads, 262/266@0.050" duration and 0.627"/0.643 lift SR cam, 3.90 gear, 28" tire, 3550#. 10.01@134.3 mph with a 1.45 60'. Still WAY under the rollbar rule. |
I'm using a two speed Taurus fan in my Poncho powered studebaker. Moves a lot of air.
Made the mistake once of bench testing a fan with it improperly secured. If you want an Accidental Murder Drone, it would be hard to come up with something more unpredictable. All I could think of afterward was how poorly it could have gone, and how embarassing the ER explanation would be.
Clutch Guys Matter _______________________________________ 53 Studebaker, 400P/th400/9" 64 F-85 72 4-4-2 Mondello's VO Twister II 84 Hurst/Olds #2449 87 Cutlass Salon 54 Olds 88 sedan |
The fan blade still hangs over my workbench as a reminder to try and not be a dumbass. It's been a little over 10 years and the arthritis is settling in like they warned me, but I have full use of the fingers. Dropped a lot of nuts and bolts for the first two years but surprisingly have almost full feeling in the fingers now. The X-ray was taken just after we walked into emergency and we had gathered up parts and wrapped them up with the hand in a not-so-sanitary towel, and they just took the X-ray through the wrapped up towel.
My wife is an OR nurse and I showed her your xray. She said " what did he get it stuck in". That's a serious injury. |
I'm in the process of an engine swap and adapted a MK8 fan to a 68 shroud
I have a dual fan setup I bought for $1 off of a dude at a swap meet who didn’t want to take things home on Sunday. Codes out to a G6 if I remember correctly. I’ve been meaning to swap the fans into something usable for an old car. It’s too wide as is.
