Old 12-15-2013, 10:50 PM
lugnutx2 lugnutx2 is offline
Default 1965 1966 389 engine parts
Selling the following 1965 & 1966 389 GTO parts : WT block with caps date code E 6 5 $400, WT block with caps date code F 2 5 $400, clean intake with nice tubes and thermostat housing Date code E 28 6 , 389 cranks $100 each, front timing cover $75, harmonic balancer $40, oil pan with bolts $60, distributor clamp and bolt $15, distributor $15, GM engine mounts with original bolts $40 pair, starter brace $10, 4034 AFB carb $100 Prices don't include UPS, blocks are local pickup only unless buyer arranges shipping.
The Following User Says Thank You to lugnutx2 For This Useful Post:
Old 12-27-2013, 11:26 PM
NEW PRICE: either WT block with crank $300, local pickup.
Old 12-28-2013, 12:51 AM
GTO JOHN's Avatar
GTO JOHN GTO JOHN is offline
I might be interested in one or both of the '65 WT blocks. Are they standard bore? what condition is the cylinder walls? Are you able to secure blocks on a pallet? I can arrange shipping if your able to palletize. Thanks John 763-458-2865
John
Email jbr69gto@gmail.com
My Website www.minnesota-muscle.com
Old 12-28-2013, 01:45 AM
marxjunk marxjunk is offline
what part of Missouri? I may be able to pick them up for John if ya dont want to mess with it
Mark..
The Goat whisperer
"I spent a lot of my money on booze, crazy women, and fast cars. The rest I just squandered."
Old 12-28-2013, 11:00 AM
One block has crank, rods and pistons and is stuck from sitting, the other block has the crank and it may turn over, I'll check on that. Both have been out of the cars for 30 years, so I assume they're standard and will need bored to clean up. I'm going to try for local pickup first, if that doesn't work out I'll check into getting them on a pallet. I'm in Jefferson City 65101. Thanks!
Old 01-05-2014, 09:22 AM
both blocks for $500 or $275 each, local pickup only.
Old 01-12-2014, 10:12 AM
I'm parting these engines, if you need something, make offer. Thanks!
Old 02-03-2014, 10:37 PM
Default 389 and 400 blocks and parts
both 389 blocks with parts and a 72 400 short block $500
Old 04-19-2014, 12:05 AM
SOLD!
Old 04-24-2014, 11:28 PM
hobbygto65's Avatar
hobbygto65 hobbygto65 is offline
How much did you want for the intake?
Old 04-25-2014, 09:07 AM
$40
Old 09-06-2014, 10:38 AM
everything sold Thanks!
Thread Tools
Display Modes
