Old 04-29-2022, 07:39 AM
Mlburton83 Mlburton83 is offline
Default Best Gear Lube for 1970 Formula 400 Firebird 4 speed and 12 bolt differential
Hey...I recently purchased a 1970 Formula 400 Firebird (numbers matching) and am new to PY Online. I'm planning to change the gear lube in the 4 speed trans and rear end and wanted to see if there's a recommended fluid to use? Thanks for any assistance.
Old 04-29-2022, 08:25 AM
Murf Murf is offline
https://forums.maxperformanceinc.com...89#post6154289
Murf
ETA, NAPA carriers Sta Lube products around hear. Amazon also.
Old 04-29-2022, 10:27 AM
jhein's Avatar
jhein jhein is online now
Whatever gear oil you use, don't forget the GM brand posi additive or you'll get binding.
Also, pictures and details of your car are mandatory.
70 TA, 467 cid IAII, Edelbrock D-port heads, 9.94:1, Butler HR 236/242 @ .050, 520/540 lift, 112 LSA, Ray Klemm calibrated Q-jet, TKX (2.87 1st/.81 OD), 3.31 rear
The Following User Says Thank You to jhein For This Useful Post:
Old 04-29-2022, 11:17 AM
shermanator2 shermanator2 is offline
I contacted Valvoline a couple of years ago specifically asking what to use in Muncie transmissions from the 1960's, Here is what they recommend: https://www.valvoline.com/en/synchromesh-mtf/
And for the rear end, any quality GL-5 and I completely agree with the genuine GM limited slip additive if you have a Safe-T-Track differential. Notice I did not say Posi, it is a Pontiac after all, not a Chevy.
Old 04-29-2022, 11:26 AM
FrankieT/A's Avatar
No synthetic for Posi's, Safe T Track or any other clutch type diffs.
The Following User Says Thank You to FrankieT/A For This Useful Post:
Old 04-29-2022, 01:02 PM
Formulabruce's Avatar
On the transmission, synthetic is fine, but I like to add " MOTOR KOTE" This additive is amazing, and quiets many gearboxes.
Old 04-29-2022, 06:50 PM
turbo69bird's Avatar
After blowing up many a 12 bolt I finally switched to moroso climbing gear lube never broke one again. And I drag raced on these rears for years .
Back when I switched all the stock eliminator guys ran that lube.
960 HP @ 11 psi, 9.70 at 146.
