Old 05-04-2022, 10:10 PM
Ramairnacho Ramairnacho is offline
Default Choke stove
So im.looking at my engine I my yz formula 400 and I got choke stove 8097 is that possible in 1970? Will it work correctly on carb 7040270 or do I need 0097 choke stove?
Old 05-05-2022, 12:55 AM
Scott Thelander's Avatar
I have a couple of those 68 restamps
look close
yours has lines thru it and restamped 0097 close to the fender edge
Old 05-05-2022, 09:34 AM
Oh I wasn't aware that they are restamed 0097. I need to look on edge side wall for number?
Old 05-05-2022, 09:35 AM
Oh I wasn't aware that they are restamed 0097. I need to look on edge side wall for number? My question I have is will it warm car up correctly on a ram.air 400 car? I might be overthinking again. I do that and get stick. Lol
Old 05-05-2022, 01:48 PM
Formulabruce's Avatar
One easy way to eyeball used covers right off is that the hole for the rod is CLOSE to the middle of engine on a 2bbl carb engine.
And on outside closest to valve cover on a V8. Lots are selling used 22bl choke covers as 4bbl.
Old 05-05-2022, 01:56 PM
look close
Have several dozen original 4 bbl choke boxs. The lined "restamped 8097" version was actually done so by Rochestor Products. Can't say I've seen such a line stamped choke stove on an automatic '70 application & have owned two original '70 YZ engines & examined several others.
Old 05-05-2022, 02:59 PM
Default Chock.stove
So how do I determine what it is? Do you have a 0097 for sale in good condition. I have a new repop but would like a nice original. The 8097 might not be original
Old 05-05-2022, 03:14 PM
check........my earlier post
9098 restamped on yours n the picture
not 0097 now that im looking on a monitor instead of my phone
ID:	590268   Click image for larger version
ID:	590269   Click image for larger version
The Following User Says Thank You to Scott Thelander For This Useful Post:
Old 05-05-2022, 03:34 PM
2bbl and 67. Had the lever coming out on the firewall side
68 up had the lever on the radiator side
It also looks like there was 2 different covers for 67
The 3 67’s on the top row have a different slot where the rod enters. The lower 67 is like the 68up.
No wiggle in the opening see the left one it shows up good
And a 2bbl lower left for comparison with long rod
Old 05-05-2022, 04:00 PM
Default Choke stove
look close
Thanks you for pointing that out! I'm still a rookie and yes it's a 9098 I think I didn't notice that. I better hunt a 0097 and have a nice original. Thank you., either it got swapted out long ago or when I got original car beguile and got back a 1969 428 auto carb. I think it was 7029268. But thank got I found a 7040270
Old 05-05-2022, 04:01 PM
Default 0097
How much for a nice 0097
Old 05-05-2022, 04:20 PM
"check........my earlier post"
my above statement was meant to read
updating my first post ,....
NOT for you to check my first post .... sorry for any confusion
Scott
Old 05-05-2022, 06:51 PM
Thanks for the pics Scott.!
Old 05-05-2022, 09:15 PM
Ok so I found a 0097 hopes it's correct for ra3 70 auto. I have my ames one too. When it arrives I'll show it and compare and maybe learn more. Thanks group
