Old 03-25-2022, 09:28 AM
LT4USMC LT4USMC is offline
Default Canton 15-444 and Doug's D523
Hey Guys I've run into a potential problem and would like to ask the knowledge base if the Canton Road Race 15-444 pan will fit while using Doug's D523 Headers on a 71 Firebird. I'm about ready to install everything but I'm in a borrowed shop with little time so if I need to modify anything now would be the time rather than in a hurry later. Thanks in advance!
Sent from my SM-G988U1 using Tapatalk
Old 03-25-2022, 11:36 AM
25stevem's Avatar
25stevem 25stevem is offline
With the 2” tube size of those headers I would have to doubt it would be a drop in no mod situation!
I do stuff for reasons.
Old 03-28-2022, 09:16 PM
So no-one has used or tired to use Canton's Premier pan with Doug's Headers D523 2" Premier Headers? Wow guess I'm the first at something!!!
Old 05-04-2022, 01:44 PM
65madgoat's Avatar
I have the Canton road race pan in a 1969 firebird with the Doug's 2" headers. The dipstick tube will not go on.
The headers kissed the t-sump part on the passenger side too (noted though by Canton that it would).
Old 05-04-2022, 07:54 PM
I use the Canton 450 Road race pan with 2" Hookers no problems. Yopu can get a stock dipstick to work if you drill a hole in their baffle
Old 05-05-2022, 12:36 PM
65madgoat's Avatar
Skip it looks like you have the pan that is -not- the same as my T-sump style road race Canton pan I have dipstick issues with.....
Old 05-07-2022, 11:12 AM
Yep mine is different no kick outs but it had to be modified to take a stock dipstick. Look at the larger hole in the bottom of the pan tray -it is extra where factory dipstick hit it, try the pan no tray first and if there is a recess that can work.
Old 05-07-2022, 11:25 AM
65madgoat's Avatar
Yeah not going the stock dipstick route... told Canton they failed putting the bung in at an angle in their t-sump pan - no need. Vertical would be perfect. Their engineers dropped the ball as there is no way their pan mounted dipstick will clear any set of headers.
