Old 05-20-2022, 02:21 AM
Baba O'Riley's Avatar
Baba O'Riley Baba O'Riley is offline
Default Inner door panel removal -- door handle cup / escutcheon
Pulling the inner door panels on my '71 Formula. All the tech sites instruct you to loosen the screw on the door handle cup / escutcheon. Which is great, except on mine there's no screw to remove on those cups. How do I get this trim piece loose? Thanks in advance.
"A MAN IS ONLY AS OLD AS THE WOMAN HE FEELS."
-- Groucho Marx
Old 05-20-2022, 02:36 AM
Trevor78 Trevor78 is offline
don't the early years have the insert cover over the diecast surround with screws behind it? Later years replaced it as one-piece plastic with screws in sight.
The Following User Says Thank You to Trevor78 For This Useful Post:
Old 05-20-2022, 06:58 AM
Yes
The Following User Says Thank You to Tellyshavilli For This Useful Post:
Old 05-20-2022, 09:51 AM
78w72 78w72 is offline
if you havent figured it out yet, the black plastic plate pops off with a very small flat screwdriver prying carefully around the edge or at the corners. the screws are under that plastic trim plate.
The Following 2 Users Say Thank You to 78w72 For This Useful Post:
Old 05-20-2022, 01:41 PM
TA455HO's Avatar
TA455HO TA455HO is offline
Here's a visual of the backside from my 1971 with Standard interior.
Some of the deluxe interiors used a trim piece (below) that didn't wrap around so the chrome edge of the metal showed, and used either 4 fingers that went into slots in the metal portion (upper item - 1970 only, I believe) or two fingers and two studs.
Old 05-20-2022, 03:33 PM
Thanks to all, I figured it just pried out but I wasn't sure --and if I was wrong I didn't want to spend the weekend gluing and clamping 50-year-old petrified plastic. Happy Friday, everyone.
-- Groucho Marx
