#5861
4 WD wagon
Does that Ford wagon have the optional couch seating with suicide rear doors too?
" Darksiders Rule "
#5862
Too bad that pic is in B&W. Imagine all the colors! Certainly not the monochromatic white, black, grey, silver dominance of today's palette.
69 Judge, SURVIVOR, Carousel Red/Parchment, RAIII, 4-sp, 63k orig. miles, unrestored, #'s match 65 GTO, SURVIVOR, Tri-Power, 4-sp, 79k orig. miles, Capri Gold, orig. paint, top, interior, #'s match 70 GTO Conv, 400, at, A/C, Atoll Blue/Sandlewood/White top, all #'s match 2015 Challenger R/T Plus, hemi, Sublime |
#5863
The real question is ........Where's Waldo??
1969 Firebird 350 convertible, t-5, Carousel Red 2008 Solstice GXP 5speed manual, Sly 2008 Grand Prix, Ink Slate, Winter daily driver 2009 G8, Switchblade Silver, summer daily driver |
#5864
I spot a 59 and 57 Chevy as well. Must have been the new guys. Imagine what a mix a Chrysler plant parking lot must have looked like in the 60's. As sorry as those were built, I think they hired everyone who was fired from the other brands. |
#5865
Capitol Records
" Darksiders Rule "
The Following User Says Thank You to misterp266 For This Useful Post: | ||
#5866
" Darksiders Rule "
#5867
" Darksiders Rule "
#5868
I did a little write up when I saw this pic on another (truck) forum. I hope you all don't mind if I share it here since it's just a cut and paste:
This is Pontiac Assembly, in Pontiac Michigan (bordered by Baldwin Rd, Joslyn Rd and Montcalm). All three of my Pontiacs were built at this location. In addition to being the "home" plant for PMD, it was notable because of the "up integration" of the site. Engines (blocks, cylinder heads and intake manifolds) were poured, cast, machined and assembled right on site, for use in both the co-located final assembly plant and other assembly locations across the US. The Fisher Body portion (on Baldwin Rd) built the body structure and trimmed the interior; completed bodies were conveyed overhead (in sequence) via an enclosed overhead tram between the buildings. Rear axle assemblies were also built here, and the Engineering building and garage (where the good ideas came from) were on the same property on the Joslyn Rd side. Shown above is the fender set operation taking place on a '67 GTO. The two guys on the left (and simultaneously the two guys on the right) have swung the fender assembly (including inner) down off an overhead carrier and into position. The guy at the rear will shoot a vertical bolt into the cowl, and then open the door to shoot the horizontal bolt into the plenum. The kids at the front are, at the same time, shooting about a dozen smaller 5/16" bolts into the nose of the fender to secure it to the radiator support. After they do that they'll hook up a few small wires and busy themselves getting it ready for somebody else to set the hood on. You can see the hood hanging nose down on the conveyer behind the rear guy on the RH side. Line rate is between 60 and 70 vehicles per hour, so they will do this all in under one minute, approximately 500 times a day, potentially for the rest of their working lives. This is the area that I ran in the truck plant, nearly 20 years later. K
'63 LeMans Convertible '63 Grand Prix '65 GTO - original, unrestored, Dad was original owner, 5000 original mile Royal Pontiac factory racer '74 Chevelle - original owner, 9.85 @ 136 mph besthttp://www.superchevy.com/features/s...hevy-chevelle/ My Pontiac Story: http://forums.maxperformanceinc.com/...d.php?t=560524 "Intro from an old Assembly Plant Guy":http://67-72chevytrucks.com/vboard/s...d.php?t=342926 |
The Following User Says Thank You to Keith Seymore For This Useful Post: | ||
#5869
What was the attrition or turnover rate at any particular plant? Seems like the boys are having a good time with it, or just posing for the camera.
Ed 1968 GTO (Thanks Mom) 2006 Silverado 2007 Cadillac SRX 2015 Chevy Express |
#5870
Attrition was high.
I had 29 production operations and had an additional 6 or 7 utility men on the rolls just to cover absenteeism. Most days the line would start at 6 am and there wouldn't be enough people to cover every job. We would double up, or maybe even me as a salaried supervisor would do a vehicle or two just to get started. I never shut the line down, because I knew it would move about one spot and somebody else would shut it down. Deer season was especially bad. Those of that remained behind would work double shifts to keep the line moving. As far as clowning around, the answer is probably both. The environment was ripe for horseplay and practical jokes, perhaps because of the young age and testosterone of the workers but also to break the monotony. We had these giant elastic bands to hold the steering column/ rag joint out of the way at body drop and the guys would shoot them across the main aisle at each other. God forbid a FEMALE should walk out on the shop floor; you'd think these guys hadn't seen a woman in years, and you could track her location just based on the whoops and hollers. ANY THING to make the time go faster. K
#5871
Pontiac Dealers
" Darksiders Rule "
#5872
" Darksiders Rule "
#5873
If that outboard is water cooled there may be a problem "down the road".
#5874
Hank, the radiator is up front. LOL
Gary Get in, ShuT Up, Hang On! Member of the Baltimore Built Brotherhood MY GTO built 4th Week of March 1966 "Crusin' Is Not A Crime" Keep yer stick on the ice. |
#5875
Ta parade
The Following 2 Users Say Thank You to Tellyshavilli For This Useful Post: | ||
#5876
It's good that the kid is wearing a helmet... that little truck looks like a real wheelstander!
Anybody else on this planet campaign a M/T hemi Pontiac for eleven seasons? ... or has built a record breaking DOHC hemi four cylinder Pontiac? ... or has driven a couple laps of Nuerburgring with Tri-Power Pontiac power?(back in 1967) |
#5877
A big thank you to Photobucket for ruining much of this thread.
The Following User Says Thank You to GTOnly70 For This Useful Post: | ||
#5878
Nice Jack cover...
" Darksiders Rule "
#5879
Cape Cod bound.
Bourne bridge in 1935 when it was completed.
" Darksiders Rule "
#5880
GTO
Another assembly line photo.
" Darksiders Rule "
