Old 01-19-2015, 10:15 AM
Groucho's Avatar
Groucho Groucho is offline
Default Intake manifold differences(?)
I know there were changes somewhere around 1964(?). Can someone tell me the exact year groupings for intake interchange? THX
Big Willie and Tomika's Street Racers
STUGOTS-SoCal
Adding more power since 1971
Old 01-19-2015, 10:33 AM
Stuart's Avatar
Stuart Stuart is offline
Fred Teufert has an interchange chart on his website for various Pontiac engine parts: http://www.teufert.net/pontiac/page2.htm
Old 01-19-2015, 11:18 AM
Groucho's Avatar
thank you
STUGOTS-SoCal
Old 01-19-2015, 01:09 PM
Groucho's Avatar
I didn't know there were so many differences. I thought there were only 2-3 different intake configurations in all. That chart shows around 6.
STUGOTS-SoCal
Old 01-19-2015, 02:14 PM
Overkillphil's Avatar
That's curious, unless I am seeing things it would appear the 1970 2 barrel intake was used again in 1978! Hmmm, 70 had no EGR provisions but 78 would have.
Old 01-19-2015, 02:17 PM
tom s tom s is offline
basic 55-60,61-64 and 65 and later.301s are diff from all.Tom
Old 01-19-2015, 05:43 PM
Groucho's Avatar
That's more along what I had thought. Thank you. BTW, did you see the list that was offered earlier?
STUGOTS-SoCal
Old 01-19-2015, 08:06 PM
Tom Vaught's Avatar
Boost Engineer
Some "extras" are in the list due to the EGR provision in the manifolds.
"Basic 55-60,61-64 and 65 and later.301s are diff from all" is very true but not all of the combinations, just the basic "families"
Tom V.
Old 01-20-2015, 11:35 AM
pfilean's Avatar
pfilean pfilean is offline
61-64 saw some changes even though they would interchange from a bolt pattern standpoint. 61 had no PCV allowed for - that came I think in 62. Then the 64 3x2 was a little higher carb base. Some think of those as a "high rise". But all will bolt on a set of 61-64 heads.
Old 01-20-2015, 07:14 PM
Tom Vaught's Avatar
Boost Engineer
Another change (which helped old guys bending over fenders) was factory Aluminum Manifolds for the RA-IV and 455 HO engines. Course then pfilean could post up that the 61-64 engines could also use the 421 SD Aluminum manifolds. Where do you stop?
Tom V.
Old 01-20-2015, 08:32 PM
I posted the intakes that would bolt to the year heads.The only std deck bastard is the 61-62 SD 306 Heads and matching intakes as they have 55-60 water pattern but use the 61-64 water by pass from intake to timing cover.Also the 991 61-62 2-4 SD intake has a removable freeze plug to allow it to be used with 55-60 and 61-64 heads.Tom
Old 01-20-2015, 08:34 PM
GRX's Avatar
GRX GRX is offline
Differences not mentioned on that page ... the '67 intake was unique in that they had exhaust ports at the carb mounting flange.
here is a '68:
In 1970 they went with a more solid design in the center. This makes the 68-69 intakes a more popular choice for exhaust cross-over removal.
1969 GTO hard top ~ Std bore 400, '70-RA3 block, 670 heads, Bal. & Blue... M22, 12-bolt w/3:55s
The Following User Says Thank You to GRX For This Useful Post:
Old 05-17-2022, 11:39 PM
65madgoat's Avatar
Can anyone post the offset differences in carb flanges on stock vs popular aftermarket intake manifolds?
Old 05-18-2022, 05:27 PM
Tom Vaught's Avatar
Boost Engineer
Factory Q-jet Manifolds could be close.
Aftermarker Holley Intakes could be all over the place: Edelbrock vs Holley, Nash/Warrior
vs Holley, .................................................
Tom V.
Old 05-18-2022, 07:08 PM
Half-Inch Stud's Avatar
I remain amazed that 1968 4 BBL Manifold was same for 350 thru 428HO.
As were the iron 1969 4BBL to 428HO, and iron 1970 4BBL to 455HO.
Stroke x Bore ought to determine runner size for best result, yet CSA didn't budge.
Old 05-18-2022, 07:21 PM
25stevem's Avatar
25stevem 25stevem is offline
They did not need to budge it I would have to say!
Just look at the power level that can be made with a 67 and up non EGR intake manifold .
I do stuff for reasons.
