69 Bird Clutch/Brake Pedal Options
When doing an auto to manual conversion on a '69 Firebird, what pedal options are currently available?
I know the 69 has a 1 year only bolt style retaining bracket. Outside of sourcing an OE clutch/brake pedal assembly, is a 1969 Camaro bracket and its corresponding pedals a direct replacement? I'm currently unable to find any OE parts, so this is really the only thing at this point preventing me from ordering a transmission.
Hello
I have a 69 brake pedal for the 4 speed ,, maybe the hanger ,, thru firewall push rod and bell crank ,,, frame bracket ,, sweet bellhousing ,, flywheels... and stuff if needed Scott 2o6 465 91six5 I NEED a 69 clutch pedal if anyone has one ... thanks to make this set more complete for someone |
Parts
Pictures
Scott 206-4six5-91658 |
Make sure you're going with the one for a Firebird, Camaro is different. The reverse and clutch safety switch are unique to the Firebird, the Camaro one is NOT the same!
Cholesterol Bad Adrenaline Good Do it till your eyes bug out! |
Since my car is an auto by birth, I have zero of these components and they aren't in reproduction.
69 4 speed stuff
Yes no clutch pedal
Pontiacs have the round circles on the metal pedals The 2 69 brake pedals for the manual trans are picture d next to a 67-68 pedal for Camaro See how the top pivot bracket changes for the 69 On the left side seems a little wider and reinforced Ring me if you have any questions if you want Scott Thanks!!! |
boxing up stuff for the swap meet
were you interested in any parts Scott |
Scott, unfortunately without the clutch pedal, I wouldn't be interested. I'm going to have to change this whole thing over to a 69 camaro carrier and pedal set.
If you don't end up getting rid of these parts at the swap meet and come by a correct clutch pedal, I would absolutely be interested. Thank you! Oh and just for information in this thread is somebody searches in the future, the 1969 Camaro carrier bracket is a direct fit for the 69 Firebird and will then allow you to use the 69 camaro clutch/brake pedal. Not proper for a concourse restoration of course, but for a driver, will work.
NPD
I just noticed that in the Firebird NPD catalog they show 1969 Brake and clutch pedal assembly for 79.99. Will that work with the Automatic support bracket I don't know?
1970 T/A |
Just looked at them, they are not correct. The use the wrong mounting system for the 69 Firebird pedal hanger assembly. The '69 bird uses a bolt through setup while the Camaro/Nova assembly uses a slide pin setup.
Any time you see this part and it is listed as fitting 69 Camaro/Firebird and 68-72 Nova, it is not the correct part for a 69 Firebird. As mentioned, this set of pedal will work, if you also change to the 69 Camaro pedal hanger. They are not correct for a concourse or high value car restoration though.
Here's some pics of some pedals I just listed on eBay for a 69 Firebird.
Pedals
Pedals Look to be Camaro with the pivot pin rather than a pivot bolt
Good catch. Bought these many years ago and apparently they are Camaro. Listing is pulled. Thanks.
