Performance Parts For Sale/Wanted Just Performance, non-stock, trailers, tools and related accessories here. |
Race parts For Sale
S-K tunnel ram, drilled/tapped for port nozzles $800
S-K water crossover $100 Adaptor S-K to Hilborn 4-port injector $l50 2 Holley center squirters (660 cfm?) w/velocity stacks, stored for 37 years $100 Edelbrock P20 blower manifold, drilled/tapped for port nozzles $500 Hilborn PG-150A pump, rebuildable $50 BDS unused polished idler pulley bracket, w/added screw adjustment $80 Four 1/2" pitch pulleys, 31/33/34/36 tooth $50 each Three 1/2" pitch belts, used but okay, 2-54", 1-57" $20 each Wyotech rev limiter for magneto $120 9 M/T 2014-alloy rods, unused, a little surface corrosion to polish off $200 Moon timing cover, like new w/good dual-lip Viton seal $500 [sale pending] 401 c.i. longblock (honed .004" to 4.125"), M/T alum. rods, J-E blower pistons (10:1), -16 heads (unported, stainless valves, H-S roller rockers), Total Seal ZGS rings, needs one head gasket, in dry storage- turns free $2,000 [less $100 if I keep the ancient cam/lifters) Also: tractor pulling Headers-by-Ed $200 [pictured is this 401 with a forged crank and 6-71 on alky, turning 8,300 most runs]
Anybody else on this planet campaign a M/T hemi Pontiac for eleven seasons? ... or has built a record breaking DOHC hemi four cylinder Pontiac? ... or has driven a couple laps of Nuerburgring with Tri-Power Pontiac power?(back in 1967) Last edited by Jack Gifford; 03-22-2022 at 01:32 AM. |
What size are the port openings on the T Ram ? What heads were they run on ?
Thanks. |
I would like to get this. Sending a PM
DragStarLeMans |
blower manifold
Inline for SK tunnel ram and water cross over
Edelbrock P20 blower manifold 2 holley 660's |
Do you have any photos of the 401 bottom end? I need more specifics, what rod length, bore & stroke. Any block fill, billet caps, lifter brace?
Sent from my iPhone using Tapatalk |
A few more:
Four 3 1/2" polished no-name breathers $20 each Two 2" unpolished no-name breathers $10 each
Answers to questions:
S-K is unported. Was run on unported -16 heads. No photo of bottom end- pan still on. Stock length 6.625" rods, stock 2-bolt mains, no block fill, 4.125"/3.750" bore/stroke, no lifter brace. Will send PMs to jspeed & drag star lemans.
Does this motor have a forged crank now or just when it was in the tractor? Cast main caps? What is the camshaft?
Jack, I will take the 9 M/T 2014-alloy rods, unused, a little surface corrosion to polish off $200. They make nice garage "Lamp Stalks" for Hot Rod Pontiac Guys.
PM me payment info. Tom V.
If deal with jspeed falls thru put me inline for the 660s
Crank is stock casting (1968?), merely balanced. Stock iron 2-bolt caps. Cam is an ancient (1958) Crane hydraulic 438C. Lifters are old GM anti-pump-ups. With it as-is, unblown, with alcohol injection it made good power to 7,200 rpm.
Tom- The rods are yours, although I wish they would be utilized for other than lamps! My blown alky 401 used them for a full one and a half seasons, usually to 8,300 rpm, making about 750 HP. Twenty-series alloys were developed by the British during WWII, named 'Duralumin' with ~4% copper. 2014-T6 has a yield strength of ~60 ksi (7075-T6 is 72 ksi). A huge number of these rods survived fuel dragster abuse in the early sixties.
Send me a PM with a zipcode, for shipping cost. Let me know if you prefer picking them up at Norwalk. Jack Gifford
All interested buyers:
I can deliver any of these parts to Norwalk '22 if desired.
Sale is pending on:
Tunnel-ram & crossover Carbs Moon cover M/T rods Pulleys (some) Blower manifold Hilborn pump Thanks
Tunnel ram, crossover, carbs, M/T rods, Hilborn pump are sold.
Moon cover & rev limiter- sale-pending. Price drop on 401 long block $1,800 or make offer (could deliver to Norwalk). Also available as a short block $1,400 or make offer. Without cam/lifters/pushrods $1,700/$1,300.
Pardon my ignorance but what is a 401? Not familiar with that size? Also would you be willing to ship the engine?
401 - A 400 honed .004” over. See OP.
" Darksiders Rule "
Thanks I saw that and assumed as much but just wanted to make sure.
Moon cover is sold.
Sale pending on 401 longblock.
Hi, Did you sell the blower manifold?
