Best Gear Lube for 1970 Formula 400 Firebird 4 speed and 12 bolt differential
Hey...I recently purchased a 1970 Formula 400 Firebird (numbers matching) and am new to PY Online. I'm planning to change the gear lube in the 4 speed trans and rear end and wanted to see if there's a recommended fluid to use? Thanks for any assistance.
https://forums.maxperformanceinc.com...89#post6154289
Murf ETA, NAPA carriers Sta Lube products around hear. Amazon also. Last edited by Murf; 04-29-2022 at 08:53 AM. |
Whatever gear oil you use, don't forget the GM brand posi additive or you'll get binding.
Also, pictures and details of your car are mandatory.
70 TA, 467 cid IAII, Edelbrock D-port heads, 9.94:1, Butler HR 236/242 @ .050, 520/540 lift, 112 LSA, Ray Klemm calibrated Q-jet, TKX (2.87 1st/.81 OD), 3.31 rear https://youtube.com/shorts/gG15nb4FWeo?feature=share |
The Following User Says Thank You to jhein For This Useful Post: | ||
I contacted Valvoline a couple of years ago specifically asking what to use in Muncie transmissions from the 1960's, Here is what they recommend: https://www.valvoline.com/en/synchromesh-mtf/
And for the rear end, any quality GL-5 and I completely agree with the genuine GM limited slip additive if you have a Safe-T-Track differential. Notice I did not say Posi, it is a Pontiac after all, not a Chevy. |
No synthetic for Posi's, Safe T Track or any other clutch type diffs.
1978 Black & Gold T/A [complete 70 Ram Air III (carb to pan) PQ and 12 bolt], fully loaded, deluxe, WS6, T-Top car - 1972 Formula 455HO Ram Air numbers matching Julep Green - 1971 T/A 455, 320 CFM Eheads, RP cam, Doug's headers, Fuel injection, TKX 5 Spd. 12 Bolt 3.73, 4 wheel disc. All A/C cars |
The Following User Says Thank You to FrankieT/A For This Useful Post: | ||
On the transmission, synthetic is fine, but I like to add " MOTOR KOTE" This additive is amazing, and quiets many gearboxes.
"The Future Belongs to those who are STILL Willing to get their Hands Dirty" .. my Grandfather |
After blowing up many a 12 bolt I finally switched to moroso climbing gear lube never broke one again. And I drag raced on these rears for years .
Back when I switched all the stock eliminator guys ran that lube.
Happiness is just a turbocharger away! 960 HP @ 11 psi, 9.70 at 146. Iron heads, iron stock 2 bolt block , stock crank, 9 years haven't even changed a spark plug! selling turbos and turbo related parts since 2005! |
