Old 05-11-2022, 09:57 PM
supersport#69 supersport#69 is offline
Default Headlight switch tool?
Is this right for 68 switch removal?
Old 05-11-2022, 10:16 PM
Half-Inch Stud's Avatar
Probably not. 2-prong needed. I use a pair of needlenose plier carefully, and also gab the switch. and give it a little twist while steady on the threaded retainer.
You know about the button to press on the switch to remove the knob-shaft right..
Old 05-11-2022, 11:49 PM
Well shoot! I guess I need to order the tool with the bezel knob set then. Ok thanks for the tip. I had forgotten about the button release.
Old 05-12-2022, 02:58 AM
Scott Thelander's Avatar
that is an ignition nut tool
put a dime in your vise grips .... it works great for the headlight switch nut at the wrecking yard... a washer etc ,
I have a 7/16 socket I cut down on 2 sides with the cut off wheel to make the tool cheap n easy ,,
did the same with larger socket for taking the flat nuts off the door glass too
Old 05-12-2022, 11:38 AM
I went ahead and just bought the tool from Ames since I was already buying the dash knob bezel set. Thanks for the tips though.
Old 05-13-2022, 01:35 PM
I think that tool also works for antenna bezel nuts.
1969 Fbird (Base, 350 & Sprint Cvt’s - 400HO & TA Hardtops)
1969 LeMans (2dr & 4dr Hardtop and a Cvt)
1969 LeMans Safari 2 seat Wagon
1969 GTO (2 Cvt, 2 Hardtops & Judge Hardtop)
1969 Catalina (3 Cvt’s & a 2dr hardtop)
1969 Ventura 2 Seat Wagon
1969 Executive 4dr Sedan
1969 Bonnie Cvt
1969 Bonnie 3 Seat Wagon (2 of them)
1969 Bonnie Brougham (4dr Hardtop & Cvt)
1969 Grand Prix SJ (2 of them)
1969 2+2 2dr Hardtop (Canadian model)
