Inner door panel removal -- door handle cup / escutcheon
Pulling the inner door panels on my '71 Formula. All the tech sites instruct you to loosen the screw on the door handle cup / escutcheon. Which is great, except on mine there's no screw to remove on those cups. How do I get this trim piece loose? Thanks in advance.
"A MAN IS ONLY AS OLD AS THE WOMAN HE FEELS." -- Groucho Marx |
don't the early years have the insert cover over the diecast surround with screws behind it? Later years replaced it as one-piece plastic with screws in sight.
The Following User Says Thank You to Trevor78 For This Useful Post: | ||
Yes
The Following User Says Thank You to Tellyshavilli For This Useful Post: | ||
The Following 2 Users Say Thank You to 78w72 For This Useful Post: | ||
Here's a visual of the backside from my 1971 with Standard interior.
Some of the deluxe interiors used a trim piece (below) that didn't wrap around so the chrome edge of the metal showed, and used either 4 fingers that went into slots in the metal portion (upper item - 1970 only, I believe) or two fingers and two studs. Last edited by TA455HO; 05-20-2022 at 02:10 PM. |
Thanks to all, I figured it just pried out but I wasn't sure --and if I was wrong I didn't want to spend the weekend gluing and clamping 50-year-old petrified plastic. Happy Friday, everyone.
