Old 05-21-2022, 12:09 AM
ekancler ekancler is offline
Default 1977 Pontiac 400ci Piston Relief
Does anyone happen to know the total relief (cc's) of the pistons used in late '70s Pontiac 400s? I've got a 1977 W72 T/A. I've read that the pistons are the same as in the base L78 400 engines. I want to know for the purpose of doing compression ratio calculations and comparing with different aftermarket pistons.
Old 05-21-2022, 12:02 PM
77 TRASHCAN's Avatar
You may have to post this in the street section, many there know, for sure, they may not wander into this section, often...
Shut it off
Shut it off
Old 05-21-2022, 12:52 PM
Thanks for the suggestion. I'm new to the forum, don't always know where to post. What's a good general rule of thumb for when to post to the street section instead?
Old 05-21-2022, 02:00 PM
Jay S's Avatar
Jay S Jay S is offline
The bevel and the valve relief’s add up to 10.5cc on that era pistons. The original pistons I have checked the compression height was 1.72”.
Old 05-21-2022, 02:11 PM
Thank you!
