67 GTO parts, all original
Variety of original parts available, all plus shipping from 47401. Can provide photos of any of these.
1964 - 1972 GM Sunvisor bracket, original, GM # 5716816, minor pitting, otherwise very good, $10 AC fuel pump, used, works, $20 Air conditioner condenser mounting brackets, excellent condition, with all bolts and clamp, $20 Rear upper control arms, $50, will clean up perfectly, need new bushings (I have the new bushings for these if needed). Positive and negative battery cables, in good condition, with heat shield on positive, $10 Harmonic balancer, no rubber, no snout (mine is cracked), $50, excellent condition 2 bbl Rochester carburetor, #7027061, $100, older rebuild, needs gaskets. Rear brake lines, steel, $15, complete, no holes, some surface discoloration TH400 cooling lines, steel, $5, good condition, some surface corrosion Air conditioner hard lines, $5 Cloyes timing set, chain + gears, S371 and S305, $10. Front antisway bar mounts, stock, complete, will need new rubber or poly bushings, $5. Thermostat housing, original, some pitting, otherwise good, $10. Front Disc Brake Proportioning Hold Off Valve, original, rebuildable, $10 |
Battery cables
I’d like to buy the battery cables if they are original type. I’ll send PM
Battery cables sold.
Front Disc Brake Proportioning Hold Off Valve is SOLD.
Parts are still for sale.
More pics
Pics of the sway bar mounts and rear control arm bushings (new).
Do you happen to have any other steering components? I'm looking for an original idler arm and original tie rod ends for 1967 GTO.
Sorry, I don't have either of those.
Dave |
PM sent
Ed 1968 GTO (Thanks Mom) 2006 Silverado 2007 Cadillac SRX 2015 Chevy Express |
Control arm bushings are SOLD.
Here is a pic of the Harmonic balancer, no rubber, the snout in the photo is cracked, $50, excellent condition |
Some 67 parts still available
Variety of parts available, mostly original, all plus shipping from 47401. Can provide photos of any of these.
1964 - 1972 GM Sunvisor bracket, original, GM # 5716816, minor pitting, otherwise very good, $10 AC fuel pump, used, works, $15 Air conditioner condenser mounting brackets, excellent condition, with all bolts and clamp, $10 Rear upper control arms, $50, will clean up perfectly, need new Harmonic balancer, no rubber, no snout (mine is cracked), $40, excellent condition 2 bbl Rochester carburetor, #7027061, $100, older rebuild, needs gaskets. Rear brake lines, steel, $10, complete, no holes, some surface discoloration TH400 cooling lines, steel, $5, good condition, some surface corrosion Air conditioner hard lines, $5 Cloyes timing set, chain + gears, S371 and S305, $10. Front antisway bar mounts, stock, complete, will need new bushings, $5. Thermostat housing, original, some pitting, otherwise good, $10. |
Most of these are available.
Can you send me a picture of the 2 barrel carb?
Post pics of the carb please
2 BBL carbs
Here are some photos of three different carbs. First two are #7027061, the third is an unnumbered rebuild. This first one is $50 + shipping from 47401.
another 2 BBL
Here is the second 2 BBL, also a #7027061, $100.
Third 2 BBL Rochester
Here is a third, an unnumbered reman. It's complete and was on my running GTO when I bought it. $75.
