Old 01-04-2021, 07:15 PM
rockdoc's Avatar
rockdoc rockdoc is offline
Default 67 GTO parts, all original
Variety of original parts available, all plus shipping from 47401. Can provide photos of any of these.
1964 - 1972 GM Sunvisor bracket, original, GM # 5716816, minor pitting, otherwise very good, $10
AC fuel pump, used, works, $20
Air conditioner condenser mounting brackets, excellent condition, with all bolts and clamp, $20
Rear upper control arms, $50, will clean up perfectly, need new bushings (I have the new bushings for these if needed).
Positive and negative battery cables, in good condition, with heat shield on positive, $10
Harmonic balancer, no rubber, no snout (mine is cracked), $50, excellent condition
2 bbl Rochester carburetor, #7027061, $100, older rebuild, needs gaskets.
Rear brake lines, steel, $15, complete, no holes, some surface discoloration
TH400 cooling lines, steel, $5, good condition, some surface corrosion
Air conditioner hard lines, $5
Cloyes timing set, chain + gears, S371 and S305, $10.
Front antisway bar mounts, stock, complete, will need new rubber or poly bushings, $5.
Thermostat housing, original, some pitting, otherwise good, $10.
Front Disc Brake Proportioning Hold Off Valve, original, rebuildable, $10
Old 01-22-2021, 12:13 PM
rockdoc's Avatar
Here are pics of the visor bracket.
Old 01-22-2021, 12:36 PM
DANTIP DANTIP is offline
Default Battery cables
I’d like to buy the battery cables if they are original type. I’ll send PM
Old 01-29-2021, 12:29 PM
rockdoc's Avatar
Battery cables sold.
Old 02-05-2021, 04:46 PM
rockdoc's Avatar
Front Disc Brake Proportioning Hold Off Valve is SOLD.
Old 03-17-2021, 11:21 AM
rockdoc's Avatar
Parts are still for sale.
Old 01-21-2022, 01:28 PM
rockdoc's Avatar
Default More pics
Pics of the sway bar mounts and rear control arm bushings (new).
ID:	582352   Click image for larger version
Old 01-21-2022, 03:12 PM
6d7gto 6d7gto is offline
Do you happen to have any other steering components? I'm looking for an original idler arm and original tie rod ends for 1967 GTO.
Old 01-21-2022, 03:15 PM
rockdoc's Avatar
Sorry, I don't have either of those.
Dave
Old 04-29-2022, 02:28 PM
OG68 OG68 is offline
PM sent
2007 Cadillac SRX
Old 06-16-2022, 03:49 PM
rockdoc's Avatar
Control arm bushings are SOLD.
Here is a pic of the Harmonic balancer, no rubber, the snout in the photo is cracked, $50, excellent condition
Old 08-28-2022, 12:17 PM
rockdoc's Avatar
Default Some 67 parts still available
Variety of parts available, mostly original, all plus shipping from 47401. Can provide photos of any of these.
AC fuel pump, used, works, $15
Air conditioner condenser mounting brackets, excellent condition, with all bolts and clamp, $10
Harmonic balancer, no rubber, no snout (mine is cracked), $40, excellent condition
Rear brake lines, steel, $10, complete, no holes, some surface discoloration
Front antisway bar mounts, stock, complete, will need new bushings, $5.
Old 01-12-2023, 05:34 PM
rockdoc's Avatar
Most of these are available.
Old 01-14-2023, 11:07 PM
gtoguys gtoguys is offline
Can you send me a picture of the 2 barrel carb?
Old 01-15-2023, 09:54 AM
dhcarguy's Avatar
dhcarguy dhcarguy is offline
Post pics of the carb please
Old 01-15-2023, 01:01 PM
rockdoc's Avatar
Default 2 BBL carbs
Here are some photos of three different carbs. First two are #7027061, the third is an unnumbered rebuild. This first one is $50 + shipping from 47401.
ID:	605263   Click image for larger version
ID:	605264   Click image for larger version
Old 01-15-2023, 01:02 PM
rockdoc's Avatar
Default another 2 BBL
Here is the second 2 BBL, also a #7027061, $100.
ID:	605268   Click image for larger version
ID:	605269   Click image for larger version
ID:	605270   Click image for larger version
Old 01-15-2023, 01:04 PM
rockdoc's Avatar
Default Third 2 BBL Rochester
Here is a third, an unnumbered reman. It's complete and was on my running GTO when I bought it. $75.
ID:	605272   Click image for larger version
ID:	605273   Click image for larger version
