Old 10-30-2021, 08:10 AM
crm318 crm318 is offline
Default New Master Cylinder Sticks Out Above Hood Line
I am currently in the process of restoring a 1970 GTO and upon installation of the new master cylinder, I see that it sticks up above the hood line (it would also hit the hood tach). I bought the brake booster years ago, but I'm pretty sure it was for a 70 GTO/ A body. What could cause this issue? Do I have the wrong brake booster? It seems it's bracket could be at the wrong angle.
1970 GTO: Atoll Blue, TH400, 400 +.060, small chamber Ferrea big valve fitted # 15 heads, Summit 2802 cam, Iron intake, Cliff Ruffles 850 cfm qjet, Hooker headers, 2.5 mandrel bent exhaust, Race Pro mufflers, 3.73 Safe-T-Track.
Old 10-30-2021, 08:13 AM
Here are some pics.
ID:	576528   Click image for larger version
ID:	576529   Click image for larger version
Old 10-30-2021, 08:25 AM
Murf Murf is offline
I’m gonna say it’s some sort of “universal booster. Are the mounting brackets bolted on or riveted?
On my wife’s 65 I ended up taking the brackets off the original m/c and put them on the aftermarket m/c. It had studs holding the brackets.
If you don’t want to try that, I think you’d want to find the “correct” booster.
Good luck!
Murf
The Following 2 Users Say Thank You to Murf For This Useful Post:
Old 10-30-2021, 10:05 AM
I'll be bringing the engine to my builder on Monday. I'll give it a look.
Old 11-02-2021, 11:12 PM
1965gp 1965gp is offline
Man we had this same problem on my 72 bird. I ended up having the shop make a bracket for it. I figured it was because I went from a non power brake master to a power brake master but now I’m not sure?
Old 11-03-2021, 02:34 PM
scott70's Avatar
scott70 scott70 is offline
70 gto would have the hold off valve mounted underneath the master cylinder?
1970 GTO 455 4 speed #matching,, 3.31 posi.Stock manifolds. # 64 heads.A factory mint tuquoise ,69' judge stripe car. 8.64 @ 87.3 mph on slippery street tires.Bad 2.25 60ft.Owned since 86'
The Following User Says Thank You to scott70 For This Useful Post:
Old 11-06-2021, 01:06 AM
Formulabruce's Avatar
Yeah that set up is missing some parts, especially if the car has front Disc brakes... Even updated, it should have at least a Combination valve.
hows the rod to the pedal angle?
