Old 12-16-2021, 06:34 PM
Tim66 Tim66 is offline
Send a message via ICQ to Tim66
Default 69 gto repro radiator support
Does anyone know what needs to be done to the radiator support to make it fit.
It's a 69 gto reproduction radiator support and I was told that you need to make some adjustments,any help would be appreciated.Thank you
Tim
Old 12-16-2021, 07:00 PM
dataway's Avatar
dataway dataway is offline
"Adjustments" would be putting it lightly.
I started this thread a while back to cover much of the process.
https://forums.maxperformanceinc.com...d.php?t=835789
Some people do manage to jam them in there without the modifications I think. But I can only imagine it bites them in the ass when it comes to get the gaps right.
Old 12-17-2021, 06:35 PM
Default radiator support
Hi,thank you for responding.I looked at you're thread ,looks like I have a bit of work to do.Although you did most of it,how did it end up fitting?
Thank you again,Tim.
Old 12-17-2021, 08:58 PM
mrennie's Avatar
mrennie mrennie is offline
I had the same issues. Probably 10-15 hours of screwing around to the get the angle right and all welded back up and then found after it was painted and on the car that that it wasn't square (top rail was spot welded 1" over to one side compared to bottom rail).
These things are quite crappy unless you have nothing usable. In my case my original was rotten and badly damaged and shipping was a killer so I went with the repro.
Michael
Oshawa built 1 option Judge basket case. 463, SD KRE 295's, CNC'd factory intake, Cliff's Qjet, Stump Puller HR cam, RARE RA manifolds, Pypes exhaust, T56 Magnum, McLeod RXT clutch, 3.42 12 bolt. 24 year project almost done...
Old 12-18-2021, 07:24 AM
Carousel72TRed's Avatar
Carousel72TRed Carousel72TRed is offline
Tim
The Following User Says Thank You to Carousel72TRed For This Useful Post:
Old 12-18-2021, 01:26 PM
I have a spare 68 (oem) in New England if anyone needs it
The Following User Says Thank You to Sidponcho For This Useful Post:
Old 12-19-2021, 04:38 AM
dataway's Avatar
Have yet to get the fenders and hood installed, checked the angle of the top plate and distance to the firewall etc. and it seems good so far.
Will be spring before the rest of sheet metal is fitted.
It's a pain, but not really a huge obstacle if you have the tools. Drilling spot welds, some bending, welding. Just kind of an awkward piece to work on. A lot of my time was spent just figuring out what the heck was wrong with it. Became somewhat obvious when I took it out of the box and bolted it to the frame and it stood straight up. I was in denial that it could have been manufactured so wrong.
Old 12-23-2021, 06:24 PM
Originally Posted by Carousel72TRed View Post
If only that were all...right dataway?
The Following 2 Users Say Thank You to Greg Reid For This Useful Post:
Old 12-23-2021, 09:50 PM
I was only trying to help. I bought a 69 GTO for parts in the 80’s and took the core support out of it and put it in mine since it was in a fender bender and bent the original core support.The bottom holes were badly corroded and we cut them out and welded new pieces in and it came out good. Just goes to show you a lot of times these repro parts are bunk but what are you going to do since you can’t get OEM or NOS parts anymore.
Old 12-24-2021, 12:37 AM
dataway's Avatar
Hey, it was helpful, the work outlined in the catalog ALSO has to be done to make them right
Old 12-24-2021, 05:19 PM
My post wasn't intended to be critical or to 'call you out' 72 red... Hope it wasn't taken that way. I just happened to recall all of the work that dataway had to perform to get it to fit and that none of it is mentioned in the catalog.
Old 12-24-2021, 05:47 PM
No it wasn’t Greg. I was unaware of just how crappy these repro core supports are. I am glad I had a core support from my parts GTO to use in mine since my original was bent from a fender bender long ago. I really enjoy corresponding with you guys and have learned a lot from all of you. I hope you all have a Merry Christmas and
Carousel 72TRed
The Following 2 Users Say Thank You to Carousel72TRed For This Useful Post:
Old 12-25-2021, 06:46 AM
dataway's Avatar
Just thought of another thing .... The repops don't come with nuts welded on the bottom side of the top plate for the metal fan guard to bolt to, just has the holes. I used rivet nut threaded inserts rather than putting bolts in all the holes, nuts on the bottom and tacking into place (although that would be a more correct way to do it)
Old 12-25-2021, 08:38 AM
n20ta2's Avatar
n20ta2 n20ta2 is offline
My repro is horrible as well. It was on the car when I bought it and the top of mine was welded 1"off as well. someone shifted it 1/2 inch over at the mount and then elongated the fender holes to shift the fenders in the same direction. I fixed it but what a pain.
1969 GTO street strip project 11.1 forged 461, highport heads
1995 Trans-am 420 ci sb 14:1 compression 9"ford
9.89@132 1.34 60ft SOLD!
Old 12-25-2021, 08:55 AM
dataway's Avatar
Jeez I hope mine isn't that way when I test fit the fenders .... it would have to come back off again and be reworked again.
Is it the whole top plate ... so that the fan finger guard and everything would be off center? If so ... huge pain, as all the holes for everything that mounts to the top would have to be re-drilled. So far mine looks like the fan and everything is center properly.
I don't understand why not one vendor tells you how horrible they are, must have shipped 20,000 of them in one batch years ago and everyone wants to unload them.
Old 12-26-2021, 08:10 AM
n20ta2's Avatar
It was the top rail like mrennie posted above. I cut the tack welds and slid it over to line up with the bottom rail. You should be able to pick it out easily if yours is the same way.
The Following User Says Thank You to n20ta2 For This Useful Post:
Old 12-26-2021, 09:23 AM
mrennie's Avatar
I found out too late that mine was "off" as it was already painted and was during the panel alignment that I figured it out.
I ended up enlarging the bolt holes at the bottom corners for the lower fender brackets as well as the bottom rad support mounts and lower valance panel and shifted everything around so most things are "half wrong" rather than anything being really noticeable.
Again, these things are a total POS that take a lot of work to make close to right. It is good these things are available but as others have said, they should come with a disclaimer and instructions on all the work required to get them correct.
Michael
The Following User Says Thank You to mrennie For This Useful Post:
