Old 01-02-2022, 10:01 AM
Yellow Bird Yellow Bird is offline
Default Vacuum Port Help
Attached is a picture of an open port. Can someone please tell me if a vacuum hose goes on this port under my air cleaner and what the hose connects to? This is a Quadrajet carburetor on my 1977 Transam 400.
Old 01-02-2022, 11:01 AM
burd's Avatar
burd burd is offline
That goes to the trans. You have another port plugged og there too.
🧩 Burds Parts, Finding those Hard to Find PCs, no Fisher Price Toys Here
Just Say No To 8” Flakes
F ire B irds
Old 01-02-2022, 11:07 AM
Skip Fix's Avatar
Skip Fix Skip Fix is offline
Yes vacuum modulator hard line has a nipple that plugs in and a rubber hose over the connection.
Skip Fix
Old 01-02-2022, 01:18 PM
Thank's so much for the information. Every friggen port on my engine has a line to it and one extra outlit was driving me crazy. The transmission, whod a thunk it?!? Again, thank you.
Old 01-02-2022, 01:33 PM
"QUICK-SILVER" "QUICK-SILVER" is online now
Have you got the metal line that runs from the modulator valve to that vacuum port?
Clay
Old 01-02-2022, 03:14 PM
Clay, thanks for asking but, the lines I have are still on the shelf that were placed there 20 years ago. Slowly, ever so slowly I am getting there.
Old 01-02-2022, 03:17 PM
burd's Avatar
HVAC should pull vac from the tree also
F ire B irds
Old 01-03-2022, 01:47 AM
nUcLeArEnVoY's Avatar
nUcLeArEnVoY nUcLeArEnVoY is offline
On manual cars, that port is capped. It's usually the one I like to tap for manifold vac readings when I'm tuning the carb.
The larger port to the right of it in the pic goes to the AC controls, smaller to the secondary pulloff, or at least to a TVS that regulates the secondary pulloff.
The left port goes to different things depending on model years.
1979 Trans Am W72 400/4-Speed WS6 - Starlight Black Hardtop
