Old 01-14-2022, 07:22 PM
n20ta2's Avatar
n20ta2 n20ta2 is offline
Yes, I was thinking the same thing. I'm inclined to leave it at 108 as others have mentioned unless anyone can see a real reason not to.
1969 GTO street strip project 11.1 forged 461, highport heads
1995 Trans-am 420 ci sb 14:1 compression 9"ford
9.89@132 1.34 60ft SOLD!
Old 01-14-2022, 10:48 PM
n20ta2's Avatar
Originally Posted by Mike Davis View Post
With that converter and gear I would leave it where it's at personally.
I don't think you will see much difference between 108 and 106.
Thanks, I'm really leaning towards doing that, I'm realy hesitant on bringing it down to 106. Almost seems like deviating that far from comp's intended specs makes me think I should have chosen a cam ground on a 106.
Old 01-14-2022, 11:10 PM
bluegoat65 bluegoat65 is offline
why call Kauffman and not do what they say? They do this every day!
Old 01-14-2022, 11:39 PM
n20ta2's Avatar
Emailed him, but that's besides the point. 108 is close, I could end up messing with the timing on this cam and end up below 106. Jeff said he would try to get closer to 106 and I may actually give that a shot but if it ends up much lower then 106 with the available slots I have in the timing gear I will just put it back at 108. He actually sent me this cam when I asked for a reccomendation and said nothing about setting it at 106. If he thought this combo should run a 106 not sure why he would reccomend the 110 to begin with.
Old 01-15-2022, 12:08 AM
Dude, slow down, your even stressin me out. Stan Weiss a great contributor of analytics to this site is only giving perfect world results. 10 out 10 of the same spec built motors are not going to run the same. Kauffman , the Butlers and many everyday pontiac engine builders that do this everyday, I would take their advice and move from there. They deal with real world performance. If your really into tuning to best performance, you need to play with the cam timing and find what best works for your package. Its work to do that. Thats why guys like Langer and kinsler are it in the Pontiac world. No disrespect to anyone here, just my opinion.
Old 01-15-2022, 12:39 AM
AG's Avatar
AG AG is offline
The cam card says a LSA of 110 and the cam timing events are for an ICL of 110 degrees which would infer an installation with an ICL of 110. If Kaufmann recommended the cam install at an ICL of 106 degrees then that's probably where it should be. An ICL of 108 degrees probably won't matter much compared to 106 degrees so either way should be good. Repositioning at 106 ICL will only take another 15 minutes if you want the change.
1967 Firechicken, 499", Edl heads, 262/266@0.050" duration and 0.627"/0.643 lift SR cam, 3.90 gear, 28" tire, 3550#. 10.01@134.3 mph with a 1.45 60'. Still WAY under the rollbar rule.
Old 01-15-2022, 08:30 AM
n20ta2's Avatar
Yeah I'm going to give it a try. I'm assuming I should use the plus 2 to get it from 108 to 106?
Old 01-15-2022, 08:32 AM
n20ta2's Avatar
And thanks everyone for the advice, it's much appreciated!
Old 01-15-2022, 07:46 PM
n20ta2's Avatar
Ok, I tried the -2 that got me to 109.5 so I then went to +2 and I'm at 105.5. Kauffman suggested the 106 and that's where I'm leaving it. Should be ok I hope!
