#41
70 TA, 467 cid IAII, Edelbrock D-port heads, 9.94:1, Butler HR 236/242 @ .050, 520/540 lift, 112 LSA, Ray Klemm calibrated Q-jet, TKX (2.87 1st/.81 OD), 3.31 rear https://youtube.com/shorts/gG15nb4FWeo?feature=share |
#42
Not to Hijack........ It's just nice to see a recent post from Cliff. Carry on.
The Following 2 Users Say Thank You to mgarblik For This Useful Post: | ||
#43
Agreed!
#44
"IF tuned properly. I have rebuilt and tweaked my fair share of them, and found the hotter the engine, the bigger the pump shot needed so it does not bog down when you nail the throttle. It really depends on what the set up is that a Q-Jet is sitting on - in my case I run a old ported Holly Single Plane Manifold (back in the day that is what Herb Adams used), Race Ported RA3 heads (Nunzi), and a HO HC-03 Cam with 1.65 rollers, and could never get the Q-Jet to like that set-up. Prob cause I could not get the pump shot and tip in tuned correctly,"
The pump shot although important and a "player" in that deal really only plays a minor role in the issues you were seeing. If you are experiencing hesitation, stumble, bog or noticeable transition going quickly onto the secondaries the cure is going to be in the secondary POE system, choke pull-off release time, secondary air door spring adjustment and hanger height/metering rod being used. "Bog" is more times than not a momentary lean condition when the engine gets too much air and not enough fuel. The Quadrajet out of all the carburetors out there has the best set-up and fully adjustable in seconds, but most folks just don't know where the problem lies or how to address it........Cliff
#45
"Hi Cliff. That's great information, thanks. It's funny because one of the engine builders I talked to (not the one I'm using) flatly refused to build me an engine with the stock intake and Qjet. Just said no. Now, MY Qjet is obviously not YOUR Qjet... Clearly they must have known that. "
Last time I looked it was 2022 and we should be past all that by now, but sadly many parts including the Q-jet still get a bad reputation when it comes to these things. Usually the same folks who bad mouth the factory carburetors do the same for stock type distributors and use some sort of "bug zapping" unit in their engines as well, which don't make any more HP anyplace than a well set up stock unit. A recent and good read being that stories and real life experiences are helpful with these things, so here goes: I got involved with a "stock appearing" early 70's Chevy project that was pretty much going to be a "max-effort" deal but look completely stock. It was a big block 454 and used the factory "flat" iron intake and Cowl induction set-up. The owner hired a very good engine builder who owned a machine shop and dyno. Common with this sort of thing during the planning stages he mentioned that a "quadra-junk" and that "POS " stock flat iron intake those engines used "will not feed my engine". I hear that a lot so really didn't pay it much mind as I've been involved with quite a few of those set-ups that are raced in FAST and some run deep into the 10's and a few even dip into the 9's when the sun, moon and stars line up well. Anyhow, I went ahead and built a carburetor for the 496CID high compression 454 he was building. It would use the factory heads but they got bigger valves and ported, plus a custom cam, and all of it fitting under the stock valve covers and completely factory appearing in every respect. The target level for power was around 560-600hp and hopefully at least that much torque. The build was completed and I shipped the engine builder a custom early 1970's Chevy Q-jet modified and tuned for what they were doing. Dyno day I get a phone call and it was all BAD. The engine wouldn't make much past 425hp and it was DONE by 4500rpms or so. Along that info I got to hear all over again what a POS the carb and intake set-up was and a little "I told you so" to go with it. So I start asking questions and made a few recommendations one being to crank up the fuel pressure to make sure the carb was staying full, but nothing they did helped. I finally ruled out the carb and asked about the distributor, total timing, when it was be "all in" etc. Very quickly the engine builder snapped back at me that he did the stock points distributor himself and outfitted it with a Pertronix and custom advance curve all in around 2800rpms or so. Hum, since the engine was basically shutting down at 4500rpms and not making mcuh power I asked him to remove the Pertronix and put a good set of points back in it. The phone went silent for a moment, then he agreed. About an hour late I get a call that the next pull on the engine was 565hp and 585tq and it pulled right to 6000rpm's without much effort! This is NOT the first time I've seen this issue with Pertronix units and other aftermarket ingnition systems/modules. Of course I didn't get any apologies and wasn't expecting any, but was glad that the sorted it all out.......
The Following 2 Users Say Thank You to Cliff R For This Useful Post: | ||
#46
Right on here -
"but most folks just don't know where the problem lies or how to address it." I did tune it at first when after some minor mods to my engine like eliminating the Emissions stuff, recurve the distributor, etc. The " how to" and Q-Jet parts kits were great for simple tweaks. And the car ran great. That was 40 years ago. But just saying things get a little more complicated when moving far away from stock, and really needs a pro or dyno for making iterative changes to the Q- Jet, or any Carb for that matter to improve response and power. I did mess with all of the "secondary POE system, choke pull-off release time, secondary air door spring adjustment and hanger height/metering rod being used", but never could get it right. Lot's of Q-Jet tuning books out there, and I had them all. Like you state, lots of the tuners/pros won't even look at the Q-Jet, like it is some kind of Covid Virus At some point, it was time to go try plan "B", and in the end, for me at least, tuning a Double Pumper was just friggin easier to get better performance than the Q-Jet. |
#47
#48
NEVER had ANY dyno operation attempt to tune a qjet…….that would almost be laughable. I couldn’t imagine a dyno shop busting into his qjet tuning kit complete with specialized drills, rods, jets, hangers etc…etc..
Bring your own qjets and parts if you want to go down that road…..and frankly, I’ve not had success translating dyno tune to the track. Seems once I get on a track, the “dyno tune” goes out the window.
71 GTO, 463, KRE 295 cfm heads ported by SD Performance, RPM intake, Qjet, Dougs Headers, Comp cams HR 246/252 ...11 to 1 , 3.55 cogs, 3985lbs.....day three- 11.04 at 120mph ....1.53 60', 6.98 1/8 mile |
The Following 4 Users Say Thank You to mchell For This Useful Post: | ||
#49
Karl |
The Following 2 Users Say Thank You to 72LuxuryLeMansLa. For This Useful Post: | ||
#50
Karl |
#51
Nearly all new engines use a version of silicon cast aluminum pistons. So yeah, Forged pistons are harder on the cylinder bores. They are harder than the block casting... Forged are Great for racing, and they have their place.
"The Future Belongs to those who are STILL Willing to get their Hands Dirty" .. my Grandfather Last edited by Formulabruce; 01-16-2022 at 11:11 PM. |
The Following User Says Thank You to Formulabruce For This Useful Post: | ||
#52
The bigger the better
Hi pal … for me since not a daily driver I’d go for the gold!! (Actually I did with mine)
Love it I have too much gear (3.73) too much compression too big a carb and all the cubes I could afford (463) too much cam rattles windows rear ground pounder AND I Wouldn’t change a thing !! |
#53
I have 2618 pistons in a mild 505. With an aftermarket block I'd probably be leery about hyper pistons, but I would do 4032 alloy if I could do it over again. I don't mind the noise but I don't really see the point of 2618 pistons in a basic pump gas street engine. For a factory block street engine I would feel just fine with a hyper piston, as long as the compression ratio is safe.
The Following User Says Thank You to i82much For This Useful Post: | ||
#54
My only word of caution if considering using hypereutectic pistons is their very poor resistance to detonation. Being very hard and brittle, they have little tolerance for detonation and if your combination ever experiences audible detonation, it will result in piston damage over time, sometimes in spectacular fashion. First the ring lands generally crack and can sometimes break the rings, then as the damage progresses, the skirts tend to break right under the oil ring groove. Things can get ugly at that point. Most factory supplied hypereutectic pistons are used in applications with factory detonation sensor systems in place to keep these things from happening. If you keep your compression low, have your fuel and timing correct for the fuel, then they can be a good choice. They do run quieter than forged, but for old muscle car engines, with point ignitions and carburetors, I like the extra safety forged pistons offer.
The Following User Says Thank You to mgarblik For This Useful Post: | ||
#55
I'm on the same page. Been a forged piston guy for decades and build everything with them, which are primarily street cars. Today with pump gas what it is, never knowing what you're getting from one tank to the next, I prefer the piece of mind that I have a piston in there that'll take a little abuse, just in case.
I've never had an issue with forged pistons, even for well over 100k miles. Never made any noises for me, never had a block with issues because of them. Nothing wrong with other options. Having those options is great for budget minded builds. |
The Following User Says Thank You to Formulajones For This Useful Post: | ||
#56
"NEVER had ANY dyno operation attempt to tune a qjet…….that would almost be laughable. I couldn’t imagine a dyno shop busting into his qjet tuning kit complete with specialized drills, rods, jets, hangers etc…etc.."
I've been on the dyno (engine) with Q-jets scores of times and they are a LOT easier to tune than anything else out there. All that you need is a complete set of fully machined secondary metering rods. NEVER touch the primary side of the carburetor when dyno tuning. You may get some odd looks from the dyno operator when they are doing a "run-in" on the engine and it shows "lean" at light load. They will NOT be used to seeing that since most of if not all of their experience will have been with pretty "generous" aftermarket carburetors. NEVER let anyone yank the top off the Q-jet and start changing or drilling out the jets. Once you start making pulls make secondary metering rod changes only. If you have a set of machined rods from the same cores with the same tip length you will NOT have to mess with hangers. If your arsenal of secondary rods are from stock Q-jets you may need to change hangers with secondary metering rod changes to go the intended direction and get the results you are looking for. Track tuning? I've chased that deal to DEATH and don't really see big changes messing with fuel curves. This assumes the carb was pretty close right off the bench. I've tuned carburetors from "pig" rich to so lean the engine started to go "flat" and surge slightly and you'll be lucky to see a tenth and a half or so and less than 2mph difference all the way across the board. I used to play around with that deal a lot back when I was trying for every last possible hundreth of a second and best MPH, but ended up running the same rods most of the year and only leaning the carb up on those 100 degree plus days when the air was so thick you could cut it with a knife........FWIW.....
The Following User Says Thank You to Cliff R For This Useful Post: | ||
#57
Well stated I could agree more I’ve never been on an engine dyno tuning only street and track time
(best dyno anyway is ET/MPH) I ran q-jets on dirt a million laps when the were allowed |
Thread Tools | |
Display Modes | |
