Leaf Spring Isolation Pads
Hello all,
Trying to make a little progress on the 68 firebird rear end replacement. I have the front and real leaf spring pockets and shackles mounted and the rear housing is sitting on top of the leaf springs. I purchased some polyurethane leaf spring isolation pads but I'm really struggling with getting the locating pins to get seated. The pads fit well into the housing mount OR onto the leaf spring but when I put it all together I'm not getting them to lock into place when I put it all together. When I drop the rear down onto the pad and spring the housing moves forward/back on the spring quite easily but doesn't seem lock into place. Is there a trick to this? The pads come with a metal bushing and it does fit down onto the nubby bit on the spring and does stay put but the housing slips forward/back. Suggestions? Thanks for taking the time to read this.
1968 Firebird IAIIa 522 340 E-heads Northwind with XFlow TBI 4L80E 3.50:1 Rear |
On my installation, I seated the isolation pad's peg into the lower shock mounting plate which was a fairly snug fit. Then I ran it across the spring perch until I felt the leaf spring's peg seat into the isolation pad's pocket. I used liberal amounts of white lithium grease on the leaf spring peg to aid that.
The Following User Says Thank You to JLMounce For This Useful Post: | ||
Thanks Jason, that did the trick! I didn't have white lithium but I used a little wheel bearing grease, this did let them slip more easily into the little pockets.
Thanks!
