Old 03-26-2011, 09:37 AM
Default Stripped brass fitting in radiator
Did the search but wondering if anyone had any new ideas about how to deal with a perfectly good radiator that leaks where the tranny cooling line enters the radiator?
Stripped threads on the upper cooling line.
Kind of frustrating as I just started the engine for the first time after a complete rebuild. Just ran it long enough for initial break-in and this leak started. Engine runs great and I want to play with it but I don't want to spray tranny fluid all over the thing....so, I gotta let it sit until I get this fixed.
I'm guessing I need to find an old school radiator shop.
Old 03-28-2011, 09:55 PM
GT182's Avatar
GT182 GT182 is offline
Greg, did you try retapping it to straighten out the threads? Not sure if a helicoil would work but someone might know. Or radiator shop.... they'll fix it up for ya.
Too bad you aren't up here, I know just the place and this guy is gooood. I'll stop by tomorrow and ask Dick what you can do to repair it on your own.
Gary
Get in, ShuT Up, Hang On!
"Crusin' Is Not A Crime"
Keep yer stick on the ice.
Old 03-29-2011, 12:05 PM
Actually, I think I got it. I noticed that the flare on the tube looked a little sloppy and the tube wasn't exactly straight up near the flare. I cut off about two inches of the tube and re-flared it.
When I screwed the nut in this time, it felt much better. I think I got a better seal and I think it allowed me to catch some threads that it wasn't reaching before. It tightened up pretty good but I didn't want to get carried away with it torquing it down.
I'll run it this evening to see if it still leaks.
Old 03-30-2011, 10:38 AM
GT182's Avatar
Greg, add some teflon tape if you can. Should help seal it some more.
Gary
Old 03-30-2011, 12:15 PM
Old Goat 67's Avatar
Naw Gary, teflon tape on a flared fitting will fail when you least want it to. Murphy's Law.
Old 03-30-2011, 01:27 PM
I've heard that teflon tape or any kind of sealant was a no-no on a flared fitting. Never understood it but I've heard it. I guess because the threads are not self tightening like a pipe thread?
Anyway, I ran it for a very short time yesterday and it seems fixed. I'll check it some more today.
Old 03-30-2011, 02:12 PM
GT182's Avatar
Ok you two.... it was just a thought.
Charles, get back out there and work on the GTO. LOL
Gary
Old 03-30-2011, 03:05 PM
OK, OK.
Old 03-30-2011, 09:06 PM
4dblnkldude's Avatar
I read this title real quick and thought that could not fit a striped bass in a radiator.
Old 03-30-2011, 10:07 PM
PLAY400's Avatar
PLAY400 PLAY400 is offline
On most of the rads I have there are flared fittings that screws into a pipe fitting on the rad that the line fitting fits into.
Old 03-30-2011, 10:32 PM
68gtoMN's Avatar
68gtoMN 68gtoMN is offline
AS Charlie Sheen might say, WINNING!
'68 GTO 4-spd Hardtop (11)
'68 GTO Convertible AT (1)
'70 LeMans Sport
Land of Lakes Muscle Car Classic
Facebook Event
Facebook Wall (Kurt Smith,Minneapolis)
Old 03-31-2011, 02:43 PM
I'm thinking you probably can't.
