Old 04-13-2023, 12:51 PM
i82much's Avatar
i82much i82much is offline
Default Butler Procharger kits
Has anyone used one of these?
https://butlerperformance.com/c-1459...rger-kits.html
Curious how the install went and any difficulties you may have run into. I am temporarily poor but still fun to think about
Old 04-13-2023, 07:00 PM
Butler has been working with superchargers since the Old John Welter days with Travis
Quillen doing much of the Bracket Design work and later with Mark at Luhn Performance doing additional designs.
They make good power and the designs are rock solid.
Always fun to dream.
Old 04-13-2023, 08:06 PM
My buddy has one from Luhm on a 4000 pound 64 gto 464 with non ported speedmasters streetcar he’s well into the 9’s he’s hoping for 9.3 or better this year he made a couple updates over winter.
Old 04-14-2023, 12:35 AM
i82much's Avatar
yeah i have a mild n/a pump gas 505 now., 87 cc edelbrock round ports. i like thinking about different ways to take it. maybe could send the heads out to get the chambers enlarged and not mess with the short block.
Old 04-14-2023, 07:48 AM
i82much's Avatar
Curious about cooling system issues. If I am just cruising at 2500 RPM and smacking it in the butt every now and again, do I need major cooling system upgrades?
In and of itself, the supercharger kit isn't too intimidating. It's the mods to the fuel system, carb, cooling system, etc. that start to make the project seem like overkill.
Old 04-14-2023, 05:15 PM
Just my 2¢ when my buddy went from a 541 na street engine to the 464 he didn’t change anything on the cooling system that I know of I will ask him to be sure.
Old 04-14-2023, 08:47 PM
i82much's Avatar
thank you!
Old 04-27-2023, 12:38 PM
BILL BOWMAN1's Avatar
BILL BOWMAN1 BILL BOWMAN1 is online now
I am seriously looking into this. Latest goal is to drive to Cecil Co. 20 miles tops, make a 9 second pass and drive home.
Old 05-13-2023, 11:37 PM
i82much's Avatar
honestly the biggest drawback to me is i dont think you can run a choke with a blow through. i want an all-weather car for sure and not sure i could ever bring myself to go efi.
Old 05-18-2023, 05:29 PM
bad69bird's Avatar
bad69bird bad69bird is offline
FWIW...A properly tuned blow-thru carb will be just fine. When I had my blow-thru deal, I raced in the early spring through the month of November. Never had a problem with cold start ups.
East Coast Mafia TTFMF
Making CVWHAT's great again. I guess it took a deplorable ECM member to do it!
Originally Posted by Ray Cox View Post
Holly cow we must be some dume corn huskers here in indiana or somthing!!!
Fastest Blow-thru Pontiac powered car in the Country 8.440@166.97 (3465lbs)
Fastest Pontiac CV-1 car on the planet with only 6 passes on the combo: 4.80@147.65/ 7.49@180.12MPH (3365lbs)
The Following 2 Users Say Thank You to bad69bird For This Useful Post:
Old 05-19-2023, 11:47 PM
krisr's Avatar
krisr krisr is offline
After just having done a turbo conversion to my late model thing (Holden version of the Pontiac G8), if the supporting mods seem overwhelming I wouldn’t go down this path and just keep it naturally aspirated. Most of the work is the mods to keep it alive, not just adding the air pump, even in LS world.
The Following 2 Users Say Thank You to krisr For This Useful Post:
Old 05-20-2023, 10:04 AM
i82much's Avatar
that's the thing ... i spent YEARS getting my car to the point where i can enjoy it ... now it runs great. Of course I have the urge to mess with it .... but do i wind up spending five years dorking around with the cooling and fuel systems before i can enjoy it again? or do i put some effort in one winter and get it done right the first time?
which one of you guys has a crystal ball???
Old 05-22-2023, 12:10 PM
Lot of different parts & fabrication to a turbo conversion that ACTUALLY works.
Once you get there the smile never goes away BUT not a simple bolt on deal,
krisr knows.
Charlie66 makes over 800 hp from a 206 cid (1/2 a Pontiac engine) at 40+ psi of boost.
He has years into the development of that set-up.
Old 05-23-2023, 01:42 AM
krisr's Avatar
krisr knows.
Every drive makes me smile and my 7 year old son loves it more than I do I reckon. He’s always on the edge of his seat when he hears the turbo whistle
Mammoth amount of work and I nearly walked away from it but glad I stuck it out. The car is so much better and more calmer. I totally get the turbo deal now.
Old 05-26-2023, 10:15 AM
i82much's Avatar
assuming i decide i can live without a choke ... can i put an f1a on a pump gas 505 with a big pulley to keep boost down and just kind of start off really safe? that way i could get the installation nailed down with my current fuel and cooling systems and then upgrade those down the road as i get more aggressive with the boost.
Old 05-26-2023, 02:48 PM
WHAT PULLEY DO YOU HAVE ON THE SUPERCHARGER?
Not sure what diameter drive pulley (mounted on the crank damper) comes in a normal Procharger kit.
Old 05-26-2023, 03:01 PM
i82much's Avatar
i dont have one, just trying to understand what my options are.
Old 05-26-2023, 05:32 PM
Lee's Avatar
Lee Lee is offline
I have the FAST XFI Sportsman system on my car. They make a "blow through" version, with a 2-bar MAP sensor. My car is NA, but it has been rather easy to tune. With the FAST distributor, I have total control over the timing map as well.
'73 T/A (clone). Low budget stock headed 8.3:1 455, 222/242 116lsa .443/.435 cam. FAST Sportsman EFI, 315rwhp/385rwtq on 87 octane. 13.12 @103.2, 1.91 60'.
Old 05-27-2023, 10:27 AM
i82much's Avatar
the super sniper 1250 looks fun. i guess i would prob want to get EFI working first before doing the procharger if went that route.
i already have a really nice carb though, BD-850 quick fuel. i guess i better just drive my car this summer and dork around in the winter, making changes now just means missing days when i could drive the car.
Old 10-24-2023, 10:36 PM
PontiacMatt72's Avatar
PontiacMatt72 PontiacMatt72 is offline
Is it time?
Matt
70 GTO 400 4-speed
"Turbos make no noise and leave the line like Baby Diarrhea!" - GTOGeorge
