1965 GTO Body Panel Gaps?
I'm restoring my '65 GTO and in the process of trying to fit the new full rear quarter panels, new deck filler inner and outer panels, and new taillight panel. My question is, what are the proper gaps prior to priming and paint for:
1) Trunk lid to rear quarter panel? 2) Door to rocker, door jamb, and fenders? 3) Hood to fenders Thanks, Doug |
Rule of thumb is 3/16" after paint. The more sheet metal you replace, the more difficult it becomes to achieve a constant dimension. You may find that slicing-and-dicing will be necessary especially with aftermarket panels. Keep in mind the paint thickness of primer and top coats will tighten the gap. You may also want to panel match at each jam so there is no surface variation from panel-to-panel.
FWIW
This is a page from the '66 Fisher Manual;
When I die, I want to go peacefully like my grandfather did, in his sleep. Not screaming like the passengers in his car. |
Thanks Jeff! That helps.
What point are you at on your project? Planning. Dismantling?
