Crank Trigger Mounting?
I need to move my trigger mount because I cant get the timing where it needs to be. I have a motor plate. Can someone post a few pictures on how you have them mounted. Thanks John.
A new best of 9.135 @ 145.41 71 Lemans Sport. 72 Lemans Sport. |
Thos was how I mounted mine, this was with a all Pontiac motor plate for a second gen fbody....
Chad
3500lb 10.5" tire. 5.34@134.4 with a poor 60' |
The Following User Says Thank You to dammen8 For This Useful Post: | ||
Thanks Chad. Good Idea.
Not to hi-jack your thread but I wonder how one would mount one w/o a motor plate....on a stock timing cover?
Yes, it just uses the timing cover bolts... the motor plate is what made it more complicated..
Fabricated a mount.
The Following User Says Thank You to janderson For This Useful Post: | ||
How do you tell the ignition where the trigger is mounted in relation to TDC?
The controllers I've seen need the trigger to occur at your desired full-advance value.
Anybody else on this planet campaign a M/T hemi Pontiac for eleven seasons? ... or has built a record breaking DOHC hemi four cylinder Pontiac? ... or has driven a couple laps of Nuerburgring with Tri-Power Pontiac power?(back in 1967) |
The Following User Says Thank You to Jack Gifford For This Useful Post: | ||
I have a pattern made for a bracket that would mount to the fuel pump pad, just need to get it to a guy with a CNC machine.
Can you help me Sent from my iPhone using Tapatalk |
Here's a great video to explain the system. Remember distributor gets locked out. No mechanical advance. https://www.holley.com/blog/post/eve...igger_systems/
Mounted mine to the 2 lower timing cover bolts.
The Following User Says Thank You to Scott Stoneburg For This Useful Post: | ||
Mine is mounted to a fuel pump block-off plate.
