Old 06-01-2018, 05:37 PM
wreckmastr's Avatar
Originally Posted by wreckmastr View Post
Ben Wilkerson
I spelled his name wrong sorry it's
Ben Wilkinson
ET/mph talks, bullchit walks.
6.98 @ 199mph
4.53 @ 164mph
  #42
Old 06-01-2018, 05:45 PM
chiefbigb chiefbigb is offline
Real eye candy. Thanks for sharing
Be carefull of the feet you step on today.They may be attached to the a$$ you kiss tomorrow.
  #43
dragracerx2813's Avatar
dragracerx2813 dragracerx2813 is offline
Originally Posted by 69GTO View Post
Here's something for you Bruce.. the boost greed
Who sells those hats and can you get them in different sizes ?
  #44
Old 06-01-2018, 06:19 PM
RUDOLFSSON's Avatar
RUDOLFSSON RUDOLFSSON is offline
It’s a cad file from my computer as is... that one is a 5” base with a 3.5” outlet for a hose connection.. just something I came up with the other day
*** THE BIG BRACE is here ***
  #45
Old 06-01-2018, 06:37 PM
Awesome looking parts!
Is the hat 2 pieces?
(top half and bottom half)
  #46
Old 06-01-2018, 07:35 PM
You should start making them .
  #47
Old 06-01-2018, 09:38 PM
Kevspontiacs@aol.com's Avatar
Kevspontiacs@aol.com Kevspontiacs@aol.com is offline
He doing 2 max effort twin turbo builds.
The RAV heads will be on his IAII solid aluminum block and in his burgandy car
The billet block and billet visner top end will be in his new car
Hot damn! Good for him! Those are gonna be some game changers!!!
  #48
Old 06-02-2018, 04:15 PM
Jim Robertson's Avatar
Jim Robertson Jim Robertson is offline
Wow! There are some spectacular pieces out there. A long way from Iron D ports...Crap!
Does Ben have the program for the block and the machine to carve it out? If not, who produced his?
Jim
www.raceV8s.com
1972 Trans Am drag car, 3300lbs, 468 ci, Iron D ports, 428 block, 9799103 crank, 9.48 @ 143mph, 6.0 @ 114mph in the 1/8th.
  #49
Old 06-04-2018, 07:42 PM
RUDOLFSSON's Avatar
Correct.. two piece design.. ease of machining and material selection..
Thanks guys..
  #50
Old 06-08-2018, 05:51 PM
RUDOLFSSON's Avatar
KRE stuff..
ID:	484956   Click image for larger version
  #51
Old 06-09-2018, 10:23 AM
Scott Stoneburg's Avatar
Scott Stoneburg Scott Stoneburg is offline
May not be as professional as some of the others shown here. But I made them both.
The crank mandrel has a register that locates in the balancer hub as well as the 4 bolt flange. I made the pulley to fit and the retaining sleever to hold it on.
The Alt. bracket locates the alternator low and is solid. Alternator never wiggle or throws a belt.
Both have been on the car and could use some polishing.
ID:	484989   Click image for larger version
ID:	484990   Click image for larger version
  #52
Old 06-09-2018, 01:33 PM
Good looking stuff, Scott!
Is the crank hub bolt behind the mandrel?
Or is the outside one a long bolt?
  #53
Old 06-09-2018, 02:02 PM
The crank hub bolt is behind the mandrel. The front bolt just holds the sleeve in front of the pulley. The hardest part of the whole deal was machining out the V groove. My lathe is a really old Southbend unit. All adjustments were by hand. It all started as a 6" round pc of aluminum.
  #54
Old 06-09-2018, 03:33 PM
Dragncar Dragncar is offline
KRE stuff..
Is this a recent KRE billet block. They did one years ago, never heard much more on it. The Butler boys went up to take a look at it but it seems they never used it.
  #55
Old 06-09-2018, 09:37 PM
ponjohn's Avatar
ponjohn ponjohn is offline
Yes.
  #56
Old 06-09-2018, 09:48 PM
wreckmastr's Avatar
Visner inline
6.98 @ 199mph
4.53 @ 164mph
  #57
Old 06-09-2018, 10:06 PM
wreckmastr's Avatar
KRE's Hemi
6.98 @ 199mph
4.53 @ 164mph
  #58
Old 06-10-2018, 06:01 PM
RUDOLFSSON's Avatar
Misc. stuff I machined... fuel pump block off, coolant bungs for Pontiacs, olds'pontiac shim stock ... 4340 crank snout adapter
ID:	485135   Click image for larger version
ID:	485136   Click image for larger version
ID:	485137   Click image for larger version
ID:	485138   Click image for larger version
  #59
Old 06-10-2018, 06:29 PM
slowbird's Avatar
slowbird slowbird is offline
KRE's Hemi
I always thought those had the potential to be a badass head with forced induction and alcohol/nitro but as far as ive heard they've never been tested yet
  #60
Old 06-10-2018, 06:40 PM
Handy to be able to make your own stuff. Shim stock for custom thrust costs $$ for someone else to do it. Same for custom made water necks etc..
Love what's showing up here 😀
