Old 04-25-2019, 07:15 PM
gman005's Avatar
gman005 gman005 is offline
Default Crank Trigger Mounting?
I need to move my trigger mount because I cant get the timing where it needs to be. I have a motor plate. Can someone post a few pictures on how you have them mounted. Thanks John.
A new best of 9.135 @ 145.41
71 Lemans Sport.
72 Lemans Sport.
Old 04-25-2019, 07:51 PM
dammen8's Avatar
dammen8 dammen8 is offline
Thos was how I mounted mine, this was with a all Pontiac motor plate for a second gen fbody....
Chad
ID:	510987   Click image for larger version
ID:	510988   Click image for larger version
ID:	510989   Click image for larger version
ID:	510990   Click image for larger version
3500lb 10.5" tire. 5.34@134.4 with a poor 60'
The Following User Says Thank You to dammen8 For This Useful Post:
Old 04-26-2019, 04:05 AM
gman005's Avatar
Thanks Chad. Good Idea.
71 Lemans Sport.
72 Lemans Sport.
Old 04-26-2019, 08:10 AM
Bnick166's Avatar
Bnick166 Bnick166 is offline
Not to hi-jack your thread but I wonder how one would mount one w/o a motor plate....on a stock timing cover?
Old 04-26-2019, 09:27 AM
dammen8's Avatar
Yes, it just uses the timing cover bolts... the motor plate is what made it more complicated..
Old 04-26-2019, 09:28 AM
janderson's Avatar
janderson janderson is offline
Fabricated a mount.
ID:	511014   Click image for larger version
The Following User Says Thank You to janderson For This Useful Post:
Old 04-26-2019, 10:27 AM
ponjohn's Avatar
ponjohn ponjohn is offline
How do you tell the ignition where the trigger is mounted in relation to TDC?
Old 04-27-2019, 02:30 AM
Jack Gifford's Avatar
formerly 'Pontiac Jack'
The controllers I've seen need the trigger to occur at your desired full-advance value.
The Following User Says Thank You to Jack Gifford For This Useful Post:
Old 04-27-2019, 11:23 AM
Kevspontiacs@aol.com's Avatar
Kevspontiacs@aol.com Kevspontiacs@aol.com is offline
I have a pattern made for a bracket that would mount to the fuel pump pad, just need to get it to a guy with a CNC machine.
Old 01-15-2023, 03:49 PM
Jromaine87 Jromaine87 is offline
Chad
Can you help me
Old 01-16-2023, 08:55 AM
chuckies76ta's Avatar
Here's a great video to explain the system. Remember distributor gets locked out. No mechanical advance.
https://www.holley.com/blog/post/eve...igger_systems/
Old 01-16-2023, 06:52 PM
Scott Stoneburg's Avatar
Scott Stoneburg Scott Stoneburg is online now
Mounted mine to the 2 lower timing cover bolts.
ID:	605337   Click image for larger version
The Following User Says Thank You to Scott Stoneburg For This Useful Post:
Old 01-17-2023, 01:43 AM
Mine is mounted to a fuel pump block-off plate.
