Old 12-19-2022, 04:31 PM
dcygan1 dcygan1 is offline
Default 1965 GTO Body Panel Gaps?
I'm restoring my '65 GTO and in the process of trying to fit the new full rear quarter panels, new deck filler inner and outer panels, and new taillight panel. My question is, what are the proper gaps prior to priming and paint for:
1) Trunk lid to rear quarter panel?
2) Door to rocker, door jamb, and fenders?
3) Hood to fenders
Thanks,
Doug
Old 12-19-2022, 07:16 PM
HoovDaddy's Avatar
HoovDaddy HoovDaddy is offline
Rule of thumb is 3/16" after paint. The more sheet metal you replace, the more difficult it becomes to achieve a constant dimension. You may find that slicing-and-dicing will be necessary especially with aftermarket panels. Keep in mind the paint thickness of primer and top coats will tighten the gap. You may also want to panel match at each jam so there is no surface variation from panel-to-panel.
https://forums.maxperformanceinc.com/forums/attachment.php?attachmentid=585876&stc=1&d=1646964  761[SIGPIC]
Old 12-20-2022, 06:30 AM
Thank you for your reply! That helps clarify the gap size because I've seen other sites mention 5/32" all the way up to 5/16". to achieve a finish painted 3/16' gap, is it safe to assume 7/32" for pre-paint or should it be 1/4"?
Old 12-20-2022, 07:03 AM
Jeff Hamlin's Avatar
Arrow FWIW
This is a page from the '66 Fisher Manual;
Old 12-20-2022, 07:43 AM
Thanks Jeff! That helps.
Old 12-20-2022, 08:22 AM
HoovDaddy's Avatar
What point are you at on your project? Planning. Dismantling?
