correct trunk weatherstripping for my 72 formula
i have been looking at a lot of photos of finished cars and it seems the cars i am looking at all have different weathersriping then the one i purchased from firebird central
George I ordered this on recommendations from Formulabruce. Now I sent this to friends in Michigan for pick up https://www.1aauto.com/1970-81-chevr...36/258266/1973
I think have some left over if I can find it Ill take a pic for ya same as u show for reference
1973 Firebird Navajo Orange w/shaker,1973 400/461,1972 Intake SD CNC'd,1977 Q-Jet 800 CFM w/ Cliffs Kit,Tanks Inc PA4 255 Walbro intank pump ,-8an feed/return,RobbMc Regulator,RobbMc 40 micron filter,253 CFM 6x-8's w/H.S 1:5 Roller Rockers,SD Stump Puller H/R Cam 230/236 @.050 112 lobe separation 565/.570 lift,Crower Solid Rollers,28150 Hedman Headers,3" exhaust,full tailpipes,350 Turbo,9.5" 3200 Converter,3:42 gear,8.5 posi,C/E slide-alinks,Koni adj frt shocks,Best 12.18@110.55 Lookin for 11's Last edited by cnc; 01-22-2023 at 09:58 PM. |
The Following User Says Thank You to cnc For This Useful Post: | ||
Trunk seal
I bought a soft seal.brand one 30 years ago car sat that long and it's still good. Not sure if correct but it works.
My beef with a few brands of trunk W/S I've tried is that even though it may have the right cross section shape, it is too tough or firm so doesn't squish down enough. This doesn't allow the trunk lid to close fully allowing the dreaded 'gap-o-sis'!
What's been your experience with this brand? |
maybe i will try this one
That looks pretty good. Who is that through?
firebird central
This is what I used based on FB as mentioned here https://forums.maxperformanceinc.com...d.php?t=843620
1973 Firebird Navajo Orange w/shaker,1973 400/461,1972 Intake SD CNC'd,1977 Q-Jet 800 CFM w/ Cliffs Kit,Tanks Inc PA4 255 Walbro intank pump ,-8an feed/return,RobbMc Regulator,RobbMc 40 micron filter,253 CFM 6x-8's w/H.S 1:5 Roller Rockers,SD Stump Puller H/R Cam 230/236 @.050 112 lobe separation 565/.570 lift,Crower Solid Rollers,28150 Hedman Headers,3" exhaust,full tailpipes,350 Turbo,9.5" 3200 Converter,3:42 gear,8.5 posi,C/E slide-alinks,Koni adj frt shocks,Best 12.18@110.55 Lookin for 11's |
i used the common metro brand trunk seals on 3 of my 2nd gen cars. cant say for sure if its a correct match to original but it works great, no issues with the trunk lid not closing right or having a gap & it seals water tight. just like door or window seals, when new they will take a couple weeks to compress & fit to the car but after a short time they conform nicely & doors, windows, trunk lid close as they should.
One key is that it's not TOO thick, but seals. Also stays put if you install correctly. 90% of other brands do NOT sit in the channel correctly. These also pass the dollar bill test evenly. Year or so ago my buddy and I tried a bunch on his 74 and his 70, then on my 72 with same results. With correct thickness and install its easier to tell if your seal channel is bent down or up and or leaks.
"The Future Belongs to those who are STILL Willing to get their Hands Dirty" .. my Grandfather Last edited by Formulabruce; 01-24-2023 at 02:09 PM. |
