Old 01-30-2023, 11:25 AM
GoGoat GoGoat is offline
Is the orange wire hot all the time? Is the white wire proving to be a ground when either door is open or headlight switch is turned?
Old 02-08-2023, 11:25 AM
64Lemans 64Lemans is offline
Default C Light Working!
Thanks for all the input.
I was able to finally get my courtesy light working.
I ran a 16 gauge (orange and white) from the 2 plug harness in the trunk (that came from the ribbon cable from under the back seat. Tapped into the harness for starters and the light works identical to the dome light. I will have to clean up the mess a bit, but the light is working. So excited I forgot to check the light, how it reacts to turn the instrument dial all the way (counter clockwise) i believe to see if it will come on, but i'm assuming it'll act the same way as the dome now.
Thanks again.
Thread Tools
Display Modes
