Weird brake fluid
On my car the front master cylinder bowl has perfectly yellow brake fluid the back bowl the fluid has turned orange. Any suggestions? Pedal feels fine, same brand of fluid.
What type of car?
What type of fuild? How many miles? |
The Following User Says Thank You to gtokid1968 For This Useful Post: | ||
If there is iron in the rear part of the system, the fluid may turn darker as it absorbs moisture from the air. Such as an iron wheel cylinder or caliper. You didn't mention anything about the brake system, such as aluminum front calipers that would tend to keep the fluid cleaner. You also didn't mention what you were using for fluid. DOT 3 will turn darkest fastest. DOT 4 a little slower. (absorbs water slower). DOT 5.1 the slowest of the glycol based fluids. All three of these fluids are compatible and can be used, mixed, changed at will. DOT 5, silicone fluid should not change color and can't be mixed with anything else. Hope this helps.
The Following User Says Thank You to mgarblik For This Useful Post: | ||
I changed the rear wheel cylinders on my '73 lemans last week and the fluid that came out was orange, looked like rusty water. You may have water contamination in the rear brake fluid system.
Stock ford explorer calipers on rear. Hydroboost and wilwood calipers on front
Orange = Rust. likely in the caliper bores.
Jeff |
I am gonna drain it and see how long it takes to turn again
I guess the only iron in the system is the hydroboost unit and the rear calipers
Brown indicates that your fluid has collected a significant amount of contamination, and might have absorbed moisture, as well.
OK other than just pumping it out with the pedal what method should I use to make sure its gone
That should work, hook a clear hose on the bleeder, put end of hose in a clear bottle, pump pedal until fluid in hose is clear. Suck out all the old fluid in the Master Cylinder first.
1968 Firebird 400 RAII M21, 3.31 12 bolt, Mayfair Maize. 1977 Trans Am W72 400, TH350, 3.23 T Top Everyone you will ever meet knows something you don't. Bill Nye. |
Brake fluid
Are you using the original combination valve? I just finished a complete brake job on a 72 C20 to include new wheel cylinders and all the hoses. I bled the system until I got only clean fluid. The back brakes were still locking up. I disassembled the combination valve...It was full of mud and probably now working correctly. Just a thought.
“Nothing in the world can take the place of persistence. Talent will not; nothing is more common than unsuccessful men with talent. Genius will not; unrewarded genius is almost a proverb. Education will not; the world is full of educated derelicts. Persistence and determination alone are omnipotent. The slogan Press On! has solved and always will solve the problems of the human race.” ― Calvin Coolidge |
Thread Tools | |
Display Modes | |
