Old 05-09-2005, 10:32 PM
*67firebird*'s Avatar
*67firebird* *67firebird* is offline
Send a message via AIM to *67firebird*
ok so far i got the pass side exhaust manifold off , as for the driver side i got 3 out of 4 off, the power steering box is in the way, anyone go through the same?
463 Stroker Kit.
ross pistons. h beam rods. eagle crank.
62 heads 72cc, port matched
Performer RPM-850DP
Auburn- 3.55 gear
CC HR custom grind
463 Stroker Kit.
Performer RPM-850DP
Auburn- 3.55 gear
CC HR custom grind
Old 05-10-2005, 04:16 AM
David Jones's Avatar
Take it off.
Old 05-10-2005, 09:53 AM
well what if i have trouble with that haha?
463 Stroker Kit.
Performer RPM-850DP
Auburn- 3.55 gear
CC HR custom grind
Old 05-10-2005, 10:15 AM
Thats when the passenger side rear wheel needs to be removed.
Old 05-10-2005, 11:56 AM
Bad Karma's Avatar
Bad Karma Bad Karma is offline
Go to Napa Buy some PB BLASTER!!!!! It worked Real Good on some Frozen and Rusty Bolts I had.
SPrat and tap the Bolt heads If possible. Repeat for about a week ANd Ill bet you wont snap any bolts. The stuff works great on these types of Siezed Parts.
72 Lemans
