Old 10-10-2021, 12:23 AM
blueghoast's Avatar
Originally Posted by chuckies76ta View Post
My apologies. The cam we used was called Road Paver. 246/252. Dave had 3 cams. Old Faithful, Stump Puller, and Road Paver.
We did 2-468 early 4 bolt blocks. We used Crower Solid roller lifters on Hydraulic Cams. both used 950 quickfuel carbs with torker 2 intakes port matched to heads. 3" mandrel Exhaust right out tailpipes with X over. Headers on both were Doug's 1-3/4". I believe compression was 10.5-1. Also use 1.5 Roller rockers.
Any dyno sheets, Would like to see?
GT
  #42
Old 10-10-2021, 01:26 AM
ta man ta man is offline
Originally Posted by 71 Goatman View Post
Wow, 600/600 with the Stump Puller. What compression and exhaust were you using?
I have a a 462, 10.5:1, Cliff Q-jet, Ram Air 2.5” exhaust manifolds, RPM intake, made 505hp / 570TQ with a HFT 236/244 @ .050 with 1.65 HS roller rockers. Would be will I get to update cam and exhaust If I could gain another 70 - 80 HP.
Send your heads to SD for the 310cfm package and run his OF 2.0 cam that will get the 70 to 80 hp and have great street manners and plenty of vacuum.
  #43
Old 10-10-2021, 07:30 AM
chuckies76ta's Avatar
GT
My bad, I'm off by 10 H.P. One was done in 2010 other one 2015. I always remembered 600. I think it was my engine that made the 601 torque. They both did 589 H.P. though.
ID:	574780   Click image for larger version
  #44
Old 10-11-2021, 12:34 AM
blueghoast's Avatar
Talk about some animales.
Thats some good power there, And won't care about weight either.
Good job and thanks for the dyno sheets.
GT.
