8 track don't work?
My 8 track in my 79 t/a dont work... could it possible just need to be cleaned? how do you do that?
pax |
Can you hear the motor running when you insert a tape?
Eye Candy......garage band? https://www.youtube.com/watch?v=QUPcHxHRx3s Go full screen & turn it UP! |
No you can't just makes kinda a scratchy noise.
Is the scratch noise coming from the speakers? I thought mine was bad and after checking it out I found the the motor was running and the problem ended up being bad speakers. Later I did replace the belt but mine works really good. Good luck
Some general repair information here:
http://www.8trackheaven.com/?q=node/3 My first guess with the limited info you gave is that the belt needs replacing. If you don't want to diagnose it yourself, there are a few places you can send the unit to have a perfessionul recondition it. Does the radio work ok? Have you tried different tapes and wiggling them a bit when they're in the unit?
77 Can Am W72 |
Pax |
I had mine done by Barry Fone.
The price has gone up a lot in the past 4 years, but his work was excellent: http://www.barrys8trackrepair.com/CarAudio.html |
