Old 11-27-2017, 08:39 PM
Default 1968 SR block question D100
It’s a SR block date code D100 but the block only has two mount holes on each side. All the other SR blocks cast in 70 or 71 I have seen have all five mount holes.
ID:	468816   Click image for larger version
ID:	468817   Click image for larger version
Old 11-27-2017, 09:01 PM
cgeise's Avatar
cgeise cgeise is offline
maybe a strike era block
Old 11-27-2017, 09:24 PM
PurelyGTO68 PurelyGTO68 is offline
What is the block number? Looks like a 68 block. Perhaps the date code is incorrect?
Old 11-27-2017, 10:33 PM
It's a 68 SR 4 bolt I had a 69 ram air IV SR block cast in 71 that had all 5 mount holes.
Old 11-27-2017, 10:34 PM
What does the 85650 stand for on a SR block
Old 11-28-2017, 12:46 AM
Interesting. What is the casting number? Is the number as cast or ground and re stamped?
Old 11-28-2017, 12:48 AM
Not sure anyone knows for sure. SR likely stands for "Service Replacement"....the leading digit "8" might decode 8 cylinder engine....the last 4 digits are a mystery it seems...
Old 11-28-2017, 01:02 AM
BirdBrain BirdBrain is offline
The digits after SR are a sequence. For instance, this block is SR85650. The next SR Block would be SR85651... Is the block for sale?
Old 11-28-2017, 10:52 AM
No it’s not for sale it’s my next build. The block is ground 2506 but looks double stamped.
Old 11-28-2017, 09:17 PM
lust4speed's Avatar
Here's an SR block that is in a 68 GTO Convertible. Later casting date number of September 23, 1971, smaller SR number, has the 5 engine mount holes, and drilled for 4-bolt mains with 2-bolt caps.
Did the SR numbers start over every year?
Name:	SR block.jpg
ID:	468897   Click image for larger version
Name:	Casting date Shier block.jpg
ID:	468898   Click image for larger version
Name:	Casting number Shier block.jpg
ID:	468899   Click image for larger version
Name:	SR Number Shier block.jpg
Mick Batson
Old 11-28-2017, 09:52 PM
Double stamp
Old 11-28-2017, 10:18 PM
71 lemans sport 455 71 lemans sport 455 is offline
The 9792506 that is in the picture is a 1968 Ram air I or Ram air II service replacement block that was manufactured on April 10 1970
Old 11-28-2017, 10:34 PM
Question Actually, with a 1970 cast date, it's probably a 1969 Ram Air IV Service Replacement
Although the casting/stamping number is the same for 1968 RAI, 1968 RAII and 1969 RAIV.
And, being cast in 1970, it was most likely originally a 9799914 400 2-bolt main block.
The double-stamping (with 2 different font sizes) is peculiar. I've handled about a dozen ground-and-stamped SR blocks, of various vintages from 1967 to 1973 and all had the LARGE font stampings.
I've never seen one re-stamped with the little font size. Who knows.
Old 11-29-2017, 08:34 AM
The Boss's Avatar
The Boss The Boss is offline
That pad looks machined, not cleared with a hot knife or ground.
What are the casting numbers on the caps?
And go racin' in the street.
Old 11-29-2017, 11:45 AM
With only 2 motor mount holes per side and the large "68" by the distributor hole... wouldn't this indicate the block started as a 9790071 casting?
Sent from my XT1585 using Tapatalk
Old 11-29-2017, 02:35 PM
Default You're right, it's probably a 9790071 casting
I'd guess that there is not the 'O/O' casting in the lifter valley, which a 9799914 block would have.
Boss, I thought the same thing about the ground area - it somehow looks wrong. But I was kind of concentrating on the font size of the stamped digits.
Maybe it was a new guy working on the casting/foundry line?
Old 11-29-2017, 02:41 PM
lust4speed's Avatar
Also just noticed the chrome plated hex steel block drain plug in the 2nd photo at the beginning of this thread. Now would be a good time to ditch those and go to a brass plug. Last set of the chrome plugs I came across we ended up having to carefully drill them out and extract them piece by piece. They rust very securely to the block threads after a year or two.
Mick Batson
Old 11-29-2017, 02:42 PM
It has no OO in lifter valley.
Old 10-11-2021, 08:36 PM
Just got another 400 SR block SR811992 D201 that’s 6342 higher than the other one cast 1 year earlier D100 not sure it means anything but just over 6000 service blocks would seem about right in a year. I’m wondering if the engine size was a factor in the numbers on block?
Old 10-11-2021, 08:53 PM
Maybe Rocky will see this thread?
He has some interest in these blocks.
