Old 10-24-2021, 04:51 PM
Murf Murf is offline
Default Anything of value?
I’m cleaning out my shed while I can still pick up the heavy stuff. 😁
Anyway, my friend had a 336 GMC he was always going to do something with & didn’t.
He took it apart & had it tanked. Then he let it set for 10 or so years.
I don’t know what to do with this stuff if he doesn’t want it & I don’t think he will.
Heads, intake all the tin, bellhousing, etc.
Any guidance would be welcome.
Murf
Old 10-24-2021, 07:54 PM
694.1 694.1 is offline
PM sent.
That block uses the 347-370 crank but has a small bore for some reason. My only guess is lower road taxes for small displacement??
Will fit any '55-'59 Pontiac
Still have my 1st Firebird
7th Firebird
57 Starchief
Old 10-24-2021, 09:26 PM
Safari Larry's Avatar
Safari Larry Safari Larry is offline
From my web site (link).
"The GMC/Pontiac V-8. (by Bill Hanlon) From 1955 through 1959 small (less than 2 ton) GMC trucks with gasoline V8s were equipped with Pontiac V8s. In 55, 56 and 57 they were almost identical (bigger dishes in pistons for even lower compression ratios and Bendix/Stromberg carbs) to same year Pontiacs. In 58 they used the same block as Pontiac, but only bored it to 3.875" giving a 336.1 cubic inch engine instead of Pontiac's 370. In 59 they again used the same block as Pontiac, but only bored it to 3.78" giving 336.9 cubic inches instead of Pontiac's 389. Cranks, heads, rods, were the same as same year Pontiacs -- except the smaller bore GMC engines in 58/59 required different balancing, hence different cranks."
Larry Gorden
POCI 1956 Tech Adviser
www.PontiacSafari.com
Old 10-24-2021, 09:38 PM
tom s tom s is offline
Save the crank if it's forged.Tom
Old 10-24-2021, 10:08 PM
Marked “ARMASTEEL”
Sent from my iPhone using Tapatalk Pro
Old 10-24-2021, 10:27 PM
no good
Old 10-24-2021, 10:30 PM
Stuart's Avatar
Stuart Stuart is offline
I'd think the bellhousing would be desirable for guys with pre-1960 cars who want to change from automatic to stick.
Old 10-25-2021, 12:41 AM
Jack Gifford's Avatar
formerly 'Pontiac Jack'
Originally Posted by 694.1 View Post
... That block uses the 347-370 crank...
Only if it's an early 336. The later ones will have a 389 crank & block.
Old 10-26-2021, 07:02 PM
Yes, I believe it is the later engine. The crank casting number says it’s a 389. I think.
I posted the stuff in “Other Pontiac Parts for Sale”
I hope someone can use it. I hate to send it to the recyclers.
Murf
Old 10-29-2021, 04:41 PM
So the bellhousing, clutch and starter would work 55-59 Pontiac cars?
Mu
Old 10-29-2021, 04:51 PM
Poncho60 Poncho60 is offline
If the bebellhousing is the same as the 56-57, it won't accept later more modern transmissions.
Old 10-29-2021, 05:52 PM
Near as I can tell it is appropriately the same as a more modern manual trans. I don’t know enough to know what the 56-57 trans is like. The big hole is slightly over 5 inches.
Murf
Old 10-29-2021, 08:45 PM
1958-60 bell housing on left, it accepts later transmissions. 1956-57 bell housing on right.
Larry Gorden
Old 10-29-2021, 08:48 PM
Thanks for the pic! Definitely more like the one on the left. It doesn’t have any opening at the top, though.
Is that because it’s a truck bellhousing? I tried looking up the casting number but came up empty.
Murf
Old 10-29-2021, 08:54 PM
The opening on top is normally covered with a vented plate like the 56-57 housing has. Don't know if there is a difference between truck an Pontiac.
Larry Gorden
Old 11-07-2021, 11:01 PM
Rocky 389's Avatar
Rocky 389 Rocky 389 is offline
It's a heavier piece than the Pontiac housing. I had one from a '57 GMC and the starter bolts up to the bellhousing upside down from the Pontiacs. Motor mounts are kinda similar but different.
Roll around in the excitement
Old 11-27-2021, 03:44 PM
GTO-relic GTO-relic is offline
I'm looking for a 1957 GMC bellhousing.
the one with the bigger front bearing housing hole, for transmission.
anyone here have one they want to part with ?
I see a complete setup there in picture. is that for sale ?
Old 11-27-2021, 06:33 PM
If the OP has sold his, I can fix ya up.
7th Firebird
57 Starchief
Old 11-27-2021, 07:30 PM
what do you have ?
send me a pic.
I have 5 pre-'61 Pontiac motors, so I need more than one !
1-347, 2-370's, 1-'58 GMC, 1-'60-389
pulled life from the jaws of death,
saved from the mouth of the crusher...literally...
Old 11-29-2021, 09:14 PM
Hey GTO, PM sent
7th Firebird
57 Starchief
