1974 front chin spoiler mounting diagram
I am just about finished with my 1974 T/A and have reached the point of mounting the front chin spoiler. I have looked through my assembly manual but cannot find a diagram. My car mounts the valance panel with the clips on the bottom of the radiator support. The spoiler looks like it is supposed to bolt to the radiator support close to each end. If that is the case, then those two clips are eliminated. Does someone have a diagram of how the spoiler is mounted or pics of their own car? Thanks.
1970 Trans Am 1971 Trans Am 1974 Trans Am 1978 Y88 Trans Am W72/auto 1979 10th Anniversary Trans Am 1984 Trans Am 1993 Trans Am 1999 30th Anniversary Trans Am 2001 10th anniversary Firehawk #104 2006 GTO |
I looked in the 75 assembly manual and it doesn’t show it either. IRC on mine 5 hex head screws attach it to the valance and rad support and the outer 2 screws attach it to the inside of the front fairings.
Is your valance attached to the radiator support with the clips or bolts?
I know it’s all he head screws, car is in restoration shop or I’d get pics. If my memory is correct I believe the center 3 screw into U-nuts on the valance, the next outer set screws into the rad support and the outer holes have U-nuts on them and they sit inside the fairing. The clips on the support I believe are for the valance to hold it up to the support.
Sorry, misread you post. My valance uses all hex head screws and and coarse thread screws with washers where it attaches to the bumper. Don’t forget the v shaped spacer. I’ve never used the clips on the valance. The 74/75 valances should be the same except 75 they took the turn signals out and put in the blank off plates.
Still looking for a response from someone whose valance is held in with the clips.
Do you have a fiberglass valance or a stock plastic one? I’ve had 3 75 TA’s and they have all been installed using the screws. I even had to replace the rad support with a repo and it had holes for where the u clips went on.
Mine is the original plastic valance.
Search this in the search function “1974 front lower valance help.” This thread may help you out.
Can you post the link? I searched and only came up with this thread!
Hope this works. https://forums.maxperformanceinc.com...84#post4715284
My 75’s is attached with the clip on the support. Not to say that is correct, car has been apart and painted several times in its life.
Just want to make sure we are talking about the same thing but use different names. When you say clip are talking about the nut that clips on? That's what I call U-nut. I've attached a pic of the underside of a valance. Back 5 holes (red)are mounted to the core support and the other 5 (black) is for chin spoiler. The only thing that I'm not 100% sure of if the clip nut for the outer holes clips to the support or the the outer hole on spoiler.
Repro clip.
Here is a doc.
So long, farewell. |
And BTW, this is how it was done prior to that bulletin.
(no removal of front section of spoiler)
Thread Tools | |
Display Modes | |
