Performance Parts For Sale/Wanted Just Performance, non-stock, trailers, tools and related accessories here. |
NOS CRANE HI-INTENSITY “FAST BLEED” HYDRAULIC LIFTERS PONTIAC 1955-1981 V-8 EXCEPT..
$50.00
You pay shipping from 20601. Payment: MO, PayPal, Cashapp, etc. Send me your cell number and email address for FEDEX shipping. HI-INTENSITY “FAST BLEED” HYDRAULIC LIFTERS FOR PONTIAC 1955-1981 V-8 EXCEPT 1977-1981 265-301 SET/16 Crane Hi Intensity lifters produce a "variable duration effect". At lower RPM this can reduce running duration by 6-10° and decrease valve lift by .020-.030". Hi Intensity lifters work best with a cam that requires more compression ratio than the engine actually has. Hi Intensity lifters restore vacuum, cylinder pressure and bottom end performance. As RPM increases, these lifters act more like a normal hydraulic lifter. At 2500 to 3000 RPM they will transmit the full duration and lift of the cam. Use only if the engine's compression ratio is below the minimum recommended on the application page for the cam you have chosen. Hi Intensity lifters can cause *low speed detonation* if compression is too high. Slightly more noisy than standard lifters (NOT as noisy as a mechanical cam) and can trigger knock sensors. Maximum RPM Potential: 6,500 to 7,000 RPM. |
PM sent
PM sent
I will take them.
Sold about 15 minutes ago
That was well-bought. Those are premium lifters from the "golden age" when stuff didn't fail.
Triple Black 1971 GTO |
