Old 05-13-2021, 11:24 AM
Tim66 Tim66 is offline
Send a message via ICQ to Tim66
Default tail lights
Hi guys,I have a quick question.What do you think of the new plastic tail light housings,Yay or nay?
Thanks for your input,oh I have a 69 GTO
Tim
Old 05-13-2021, 01:16 PM
1969 Ram Air 1969 Ram Air is offline
I've used both and in my opinion, metal is worth the extra money.
69 GTO Judge, Liberty Blue/Parchment, RA3, 4-speed
69 GTO, Verdoro Green, Green, 400, 4-speed
69 Firebird 400, Starlight Black/Black, RA3, 4-speed, 611 RA Inlet
Old 05-13-2021, 03:51 PM
Default tail lights
I thought the same,but I wondered how the plastic was.
Old 05-14-2021, 08:47 AM
There was a thread on this a few months ago. Most preferred metal but at least a couple of people had the plastic and said they were very happy with them as I recall.
Old 05-14-2021, 09:25 AM
Default tail lights
Thanks Greg,I thought I remembered a post like that,but of course I couldn't find it.I'll probably go with the die cast,I'd hate to get the plastic and then decide that I should have gotten the other and be out an extra 200.00 Thanks again guys,
Tim
Old 05-14-2021, 07:41 PM
gtohurstjudge's Avatar
gtohurstjudge gtohurstjudge is offline
I have seen some plastic housings that were a little warped and not perfectly straight....also you have to modify grounding for the rear lamps....use the metal ones.
Old 06-24-2021, 12:57 PM
BUQUICK's Avatar
BUQUICK BUQUICK is offline
In March 2021 I bought a set of the reproduction metal housings and was very disappointed.
Except for not being painted correctly (shown in the photo with the red X), my general impression when taking them out of the boxes was great. Then reality set in. First of all someone did a hack job of grinding the edges of the bezel before applying the black paint. Then when I placed a lens into it I discovered that neither an original nor a reproduction lens fits it very well. The lens rocks back and forth due to touching in the center and having a sizable gaps on the ends.
More than 10 hours was spent carefully grinding on them to make the lens fit the bezel, then grinding the bezel to fit the body, and finally repainting the black areas.
ID:	568766   Click image for larger version
ID:	568767   Click image for larger version
ID:	568768   Click image for larger version
Gary Steele
GTOs,Buicks,etc
www.gsrestorations.com
The Following User Says Thank You to BUQUICK For This Useful Post:
Old 06-24-2021, 02:28 PM
Default tail lights
Thank you for you're input on them.May I ask where you got them from?
Tim
Old 06-25-2021, 08:33 AM
That looks like a nice car. Mayfair Maize is a favorite color for me. My first 68 was that color.
Sent from my moto g stylus (2021) using Tapatalk
Old 06-27-2021, 09:14 PM
Two_70_Converts Two_70_Converts is offline
I see Inline Tube sells metal die cast bezels. Anyone have any experience with those?
